4 OEM TOYOTA 1999-2002 4RUNNER Limited alloy rims
Zoom-a-Loom
SOLD 4 OEM TOYOTA 1999-2002 4RUNNER Limited alloy rims with 4 like new OEM center caps. 16 x 7 5.5 Bolt Pattern 6 Lug, same backspacing as the Tacoma. These were made in JAPAN and fit many 6 lug Toyota/LEXUS Models. The front face, inside the barrel, back side of face, (every nook & cranny) and outer barrel/hoop has the same High Quality finish as the Face, 100% painted & protected. These are Arizona rims that had no corrosion, curb rash, repairs, etc. 4 Perfect, defect free, alloy cores to start with. They originally had the factory silver paint, faded by the Az sun. All 4 were straight as an arrow with perfect run-out verified. These 4 Alloys were restored in a multi-stepped process starting with a check of run-out then stripped in a chemical vat, inspected for any stress cracks & then fine media bead blasted, followed by a 2 step Powder Coat process using Automotive Grade powder in Silver. These were restored the proper & correct way, not the fast production crap you can purchase online from 100's of re-sellers. The online retailers selling this style alloy use any core they can including pitted, corroded faces, etc, you have no history of where it came from or what repair was done to it. The mystery alloy rim will be heavily Grit blasted & then powder coated with a ?? powder and the worst part is only the face & front rim edge is painted. The inside barrel, back side of face, and outer rim/hoop is left with a slight over-spray-ghost mist with 80% of the rim un-painted and susceptible to corrosion. The pictures they show are deceiving and only when you unbox the wheel do you realize it. Powder coaters are all different in their approach to finishing a wheel and they are everywhere now, spraying anything and specializing in nothing. They do not check for run-out, cracks & hidden damage, etc. I will sell these for $125.00 ea + shipping (in the lower 48 states) PM me for a quote to your zip code. They will be sent fully protected in 4 separate shipping boxes designed for alloy rims. No dissapontments and will only sell all 4 together. Keep in mind that OEM Toyota Alloy Rims hold their value & are superior in Quality compared to the aftermarket alloys coming from CHINA.
youngrk
