FS: 1999 4Runner Limited 4x4 - $10k - Tulsa, OK
seabun
Member
3/29/24 UPDATE: 4Runner has been SOLD. Thank you to everyone for looking, and a big thank you to this Forum for all the years of information I gathered here.
I didn’t see myself ever selling this, but I also didn't forsee getting married, having a family and vehicle needs changing! That said, I'm hoping to find a good home for my beloved 3rd gen. I have put a lot of love and care in maintaining it. Here are the details:
I'm the 2nd owner. Purchased in 2012. Originally sold in Tulsa at Crow Brothers Toyota. Been in Oklahoma it's entire life. That means zero rust issues.
All maintenance work done either by Toyota dealerships or myself, always using OEM Toyota parts and supplies. I have maintained all records, services and upgrades both in a binder and phone application called aDrive/Fuelly (I’m happy to export the data to you).
Also included are various supplies I have left over (OEM paint, toyota red radiator fluid, misc oem parts,switches) as well as any original parts that were changed.
Vehicle Trim Info:
3.4 L 183 HP V6 5VZ-FE, 4spd auto w/ ECT and Overdrive
Heater power mirrors
Illuminated vanity mirror-passenger
Tow capacity: 5,000 lbs
Rear Tow hitch
Timing Belt, Water Pump and Thermostat replaced at 182,000 miles
1999: Tallest OEM Springs (looks lifted already) of all 3rd Gen 4Runners
4WD: Multimatic (on demand 4wd)
Limited Trim: Power leather seats w/ lumbar support (driver and passenger), power tilt/slide moonroof, digital hvac controls (serviced 2023), silver body cladding, 6 speakers, power antenna (working), 4-wheel ABS (disc front, drum rear), cruise control, seatback pockets, 3 acc power (cig lighters) 2 front, 1 rear, fog lamps, fender flares, splash guards, color-keyed door handles and bumpers, woodgrain trim, leather door panels, leather steering wheel, power windows, privacy glass on rear windows, roof rack
Desert Dune Metallic Pearl with Oak Interior
Things I’ve added:
1. OEM wheels from 2016-19 Tacoma. 16”x7”, 25mm offset, aluminum
2. Differential (rear) breather extension into gas filler area
3. Polyurethane front sway bar end link bushings
4. Polyurethane rear sway bar bushings (Front not installed, included)
5. JDM-style fender turn signals
6. Fog light isolation mod (can be used any time, w/ high beam, w/ parking light only)
7. Dual filament bulb mod to parking/corner light for additional turn signals
8. Door jam protection (carbon fiber-style vinyl)
9. B Pillars wrapped in same carbon fiber vinyl
10. Tinted front windows 35%
11. Wellvisors window vent guards
12. OEM moonroof wind guard
13. AVS Bugflector-2 hood guard
14. OEM sport hood, painted Desert Dune Metallic
15. Yellow vinyl on fog lights
16. Hella fog light bulbs
17. Debadged rear tailgate (removed emblems included)
18. LED license plate bulbs
19. LED bulb replacement-entire interior (dome, trunk, vanity mirror)
20. LED gauge bulb upgrade (white gauges, green hvac controls)
21. Homelink GNTX-453 auto dimming mirror with compass in blue color
22. Scion Pioneer T1806 headunit with aux port in center console and custom blue/green smd leds
23. Deckplate Airbox mod
24. Intake silencer removal mod (straight pipe)
25. Manifold O-gasket upgrade
26. Huskyliner black trunk liner
27. OEM Toyota all weather mats in rear seats
28. Additional grab handle added to driver side
29. Trunk cargo net hardware added
30. 3 nozzle windshield sprayers from Tacoma
31. Fumoto valve for diy oil changes (removed but included)
32. TRD Off-Road vinyl decals in custom colors (Grey, Black)
Recent repairs:
1. New windshield (Safelite, June 2023)
2. HVAC blender door repair (Denso OEM, December 2023) Replaced cogs in original part for first time, should last 25yrs+
3. Starter rebuild (June 2023) Replaced copper contacts in OEM starter. Previous rebuild lasted 10 years
4. Driver seat belt replaced (SafetyRestore, October 2022)
5. Oil Change 5W30 Full Synthetic –10,000 mile (March 2023, 240,842 miles)
6. Engine Air Filter, Oil Filter (PureFilter, Toyota, March 2023)
7. O2 Sensors (OEM Denso, May 2023)
8. PCV Grommet and Valve (March 2023)
9. HVAC digital controller rebuild (Lifetime) – repaired known issues of stuck buttons, worn contacts
10. Coolant flush (June 2023)
11. Tire rotation (June 2023)
12. Wiper blades (Toyota, June 2023)
Items to repair:
Driver inner CV boot is ripped. Happened in 2019. Obviously drivable as-is, but if/when you decide to upgrade the suspension, you might consider replacing this as well.
Driver seat leather. Another item I planned to recover in the OEM Oak color, but held off because you may want to do black or something else. Leather replacements for the front seats range from $100-500 and can be DIY.
Center Dash Faux-wood trim. The wood trim in the Limited are notoriously brittle. I found this out earlier this year when I removed the digital hvac controller for service. On the upper left side, a tab broke. I glued it back with polypropylene-specific adhesive, and it may not bother you, but just be aware it is there. A remedy I thought of was replacing it with the stronger SR5 black trim.
Asking $10,000 Or Best Offer. Willing to travel within reason. Not interested in any trades. I tried to offer as much info as I can in this ad, the highlights, the repairs I’ve done, what could be fixed, but if you have any questions I am happy to answer them. I have learned a lot from this forum and am grateful for all of the input from its users.
Thanks for looking and have a great day! :hatsoff:
More photos:
@JRM Sorry, just seeing this. Current mileage is 244,373. No longer daily driver as of October, 2023.
