I'm surprised by all this timing belt talk. What does the timing belt have to do with the starter cranking at the flywheel? The OP has stated it won't turn over/crank.
I'd say either starter, battery or bad connections.
Mine did this last week. I changed the brushes on my alt a few weeks ago. It had been running fine since then. Last Wednesday, I noticed the idle got low at times when I came to a stop, and the voltage dropped pretty fast. If I gave a little gas, it went back up.
I was on the interstate coming home Friday and traffic built up, so I had to stop rather quickly...damn thing died on me! I put it in park, and it started right up. Its not my alternator, as it continues to charge my battery...I never have a problem starting.
It hasn't died on me since, but the idle and voltage still drops on me. I'm going to check the MAF sensor when I get home tonight...hopefully that just needs cleaned.
You may want to check your IAC valve as well...
Why is it always the ford guys that turn into toyota guys? I loved my ford but ended up loving my yota more.
I'm also trying to diagnose the same issue. 2001 LTD
Hit a bump (small pothole) and the engine died, wouldn't crank again. 1st shop said that the main relay was blowing and check all the usual suspect, but came back with nothing. Dealership is drawing a blank as well. Mechanics already checked crank position sensor and neutral switch
Looking for any ideas.
