albelee said:Hi there ...
What are the key differences, benefits and trade-offs of each type of transmission?
I want an 05 SE V-8 ... still undecided on whether I go with a 4spd or 5 spd?
Thanks!
Thanks!
fo'runner said:Yeah......Toyota should have originally put the 5spd tranny in both the V-6 and V-8's! I feel as if the 2003/2004 V-6 Runner owners got the shaft with the 4 spd jobbie!
Easy fix, just trade it info'runner said:THANKS Bulldog-yota for explaining that in GREAT detail for those who did NOT understand where I was coming from about being pissed at Toyota. The '05 V-6 w/5spd tranny will kick the socks off an '03-'04 V-6 w/4spd tranny all day long. From the 0-60 to the uphill slope climbs. I can notice the difference in just trolling around so. Calif pulling the numerous 1000-3000 ft hills we have here. The 4 spd tranny has too long of gearing ratio between 2nd-3rd-4th for good continous power. This also comes into reverse effect when going down the hill.....as the longer gears will cause a driver to ride thier brakes more. Thanks again Bulldog-yota! Now, if I could just get Toyota to update my '04 V-6 with modern day 5 spd tranny hardware!
JB. said:Bulldog,
Where in the devil did you get those gear ratios. I can't find them for the 4th gen 4runner anywhere - including toyota.com. I sure have found them for lots of other vehicles. Just not for the one I own.
I'm curious about the reverse ratio.
JB. said:Originally posted by iFORCE
You plan on racing backwards?![]()
I promised the old lady I wouldn't put any racing miles on the odometer.![]()
iFORCE said:btw, where in Nevada do you live? I'm coming to visit! well... I'm heading to Las Vegas in 4 days for 5 days.![]()
bulldog-yota said:answer to original question, is the same as above, you dont have a choice the V8 only comes with a 5 speed for all years, the V6 03-04 4 spd, later 5 spd.
Pending on your use of the vehicle 5spd can make a big difference.
I dont know what the final drive on the new 5 spd V6 is, but I did the comparison for the 5spd V8 final drive vs 4spd V6 final drive some time ago.
Transfer case V6 and V8 is 2.566
FInal drive V6 3.909 V8 3.727 (so those that went to 33" tires can gain that back by swapping the V8 gears for V6 gears in the diff about 5%)
V6 gears
1st 2.804
2nd 1.531
3rd 1.000
4th 0.705
V8 gears
1st 3.520
2nd 2.042
3rd 1.400
4th 1.000
5th 0.716
SO the V8 has a 20% shorter 1st gear ratio (with diff) than the V6 showing why the V8 is a better option offroad and towing. Also 2nd is 27% shorter and so on till top gear where the V8 is 3% taller (an extra gear helps).
so if you tow or go offroad the 5 spd has a significant advantage with much lower gears in the first 3 speeds, less strain on engine and tranny. also if you add bigger wheels/tires you will notice the effect far less.
Also for people living in very hilly/mountain areas you will have less of a tendency to shift between gears.
Even if you dont do any of these the 5 speed will leave the 4 spd in the dust at a traffic light, with the same engine, all day long. Shorter gears get you up to speed on a heavy vechile so much quicker.
If none of these are important to you, dont worry about it. In normal day to day tooling around town it will make a marginal/unnoticeable difference.
