459k just wow
I never even heard of doing that when I had mine. Only after getting on the forum did I hear about things such as Fluid Film. I think you use WD40, correct?
I had a Tacoma buyback from Toyota for a bad frame, and my first 3rd gen 4runner I didn't do any rust proofing, then I learned from those and have been protecting them ever since. Yes I lube her up with WD-40, works great as an effective old school method. Fluid Film works to. Anything you can use as a rust barrier will keep them from rusting. It has to be done correctly, and maintained correctly, and done every year.
Here's a link for how I do the WD-40 treatment
SEASONAL RUST PROOFING using WD-40 only
Thanks for the link. Yeah, I've seen some of your pics before. The results are great, can't argue with them.
Question: with no compressor or sprayer, is spray cans the only other means of application you're aware of?
You can use a spray can for inside the doors, hatch, hood and rockers. Spray cans for the whole thing is too much. You can buy a gallon of WD-40 for about $20 and get a cheap pump up garden insecticide sprayer for the rest like the frame, rear end and rest of undercarriage.
Sounds doable. Thanks for the info.
Mike Sargent
