4runner 06 Bilstein 5100 Front - Rear
Chicago
Hello , there , i would like to give a lift to my car , 0,85 in the front , with these shocks Bilstein 5100 , i can ajust the front to 0,85 .....but how can i ajust the Rear to 0,85" ? because the rear shocks doesnt have any ajustment
Any idea ?
My Car 4runner V-8 limited -2006
Thank you :jump:
Any idea ?
Thank you :jump:
you kinda answered your own question, the rear shocks don't adjust, you'd need coil spring spacers
I just put Bilsteins on all around on mine and got .75 inches lift in the rear and 3 inches in the front for the 2.5 setting.
Any idea ?
Thank you :jump:
Unfortunately in the rear of the 4Runner you need to use a spring spacer or swap springs. A lot of people look towards FJ springs for slight lift (0.5-0.75"). Cheapest option is spacers, but those are ~1.5" lift.
Please tell us how you got lift in the rear from a damper that has nothing to do with ride height. The only way to get lift in the rear is to space the springs or install longer/different rate springs. But I look forward to your explanation.
I used the same springs and no spacer and got .75 inches lift in the rear. I got solid measurements on level ground and I can visually tell its higher now. I can't really explain why other than to say my old rear struts were shot (it was XREAS, got rid of it). I know they are just dampers but it must require some force to compress them so maybe thats it.
2001ATL
