4runner hop
tighturns
Hi everyone..Has anyone had any problems with the rear of the truck jumping sideways when it hits small pot holes in the road? Is this common as in the early Ford Mustangs? Any solutions or should I just take it like a man and counter steer when needed?
weird, this has happened to me a couple times. Freaked me out.
TAKE IT LIKE A MAN
usually has happened with steep speed bumps but not pot holes.
I've experienced it too, on a bad stretch of road. The road looked like a series of 8" high whoops, about 4 of them in a row bending around a curve spread about 3 feet apart. It made the truck's rear axle hop and slightly oversteer, but nothing serious. I shudder to think what it would have been like in my '98 ZR2 Blazer, that leaf spring setup hopped like a mo fo.
Its just the nature of a solid axle to hop on occasion. Progressive rate springs and different shock valving can reduce it significantly.
I'm curious. what year and model is your 4Runner? What size tires do you have and what psi do you run?
