4Runner rear isnt level
KurtL
I noticed lately that it just doesnt seem like the rear of my 4runner is level. I have tundra 5100s in the rear with OME 890s. I measured 24" from hub on the rear left and only 23.5" on the right rear. The front appears pretty level with tundra 5100s and 881s(i think) on the 2nd perch both at approx 21.5"
Is this normal, and i should have have gotten a 10mm trim packer? If not what could be the cause? Did the 890s have a left and right coil?
Sorry, but yes there is a left and right side on the 890s. I have the same lift and almost did the same thing! I sit at 22 front and 23 rear after alignment and almost a year of driving.
if i installed them wrong would this be the culprit?
I would think the rear passenger side would sit higher because I thought they were suppose to be different to makeup for the heavier driver's side. Is it possible that the driver's side coil isn't seated correctly?
The cup/plate the coil sits on isn't perfectly flat. There's a notch/devit that the end of the coil fits into.
Everything looks to be seated correctly. And i agree, if i had the springs backwards i would expect the passenger side to be higher.
Crookedcat
