4Runner Rock Sliders (4th, 5th & 6th Gen): Step & Trail Edition specs, fitment, Q&A | Cali Raised LED
Caliraisedled
Official Vendor
Cali Raised LED 4Runner Rock Sliders: 4th, 5th & 6th Gen (updated Nov 2026)
Jake from Cali Raised LED here. This thread started back in 2018, so here's the current lineup in one place. Ask fitment questions below and we'll answer here.
Two styles
  • Step Edition: 0-degree flat top that works as a real step. Top/filler plates are optional.
  • Trail Edition: 20-degree angle that tucks tighter to the body for more clearance. No top plates.
Built the same on every gen
  • 1.75" DOM tubing, .120" wall
  • Frame-mounted with Grade 8 hardware, full gusseting
  • 100% bolt-on, no drilling or cutting
  • Kick-out or no kick-out
  • Raw, powder coat or bed liner finish (coat raw steel right away)
  • Fabricated in-house in Fort Worth, Texas
  • Free FedEx Ground to the lower 48, two boxes, no freight appointment
5th Gen (2010–2024)
  • Fits KDSS and non-KDSS.
  • Limited and TRD Sport: only after the X-REAS system and side moldings are removed.
  • Step: about 45 lbs per side, 1.5–2 hour install. Trail: about 100 lbs per set, 1–1.5 hours.
Step: https://caliraisedled.com/products/step-edition-bolt-on-rock-sliders-for-2010-2024-toyota-4runner
Trail: https://caliraisedled.com/products/trail-edition-bolt-on-rock-sliders-for-2010-2024-toyota-4runner
6th Gen (2025+)
  • Pick the frame kit that matches your truck: most 2025s need "No Threaded Frame Holes", and 2026+ have threaded frame holes. Check your frame, or ask us.
  • Step Edition: about 120 lbs per set, 1.5–2 hour install. There's an install video for each frame kit on our YouTube.
Step: https://caliraisedled.com/products/step-edition-rock-sliders-for-2025-toyota-4runner
Trail: https://caliraisedled.com/products/trail-edition-rock-sliders-for-2025-toyota-4runner
4th Gen (2003–2009)
  • Step and Trail Edition. Not compatible with X-REAS, the Limited or the Lexus GX.
Pricing starts at $909.99 a pair. Questions: reply here, call 888-385-5036 or email [email protected].
Older photos from the original 2018 post:
DSC_2145_50_480x480.jpg DSC_2147_50_480x480.jpg image_887a3ab1-fdb4-4db9-b960-4a067b93ad9d_480x480.jpg IMG_5598_480x480.jpg IMG_5596_480x480.jpg
Y'all sure they don't fit the 2010-2013? I can take off the side skirts if thats all it takes.
I am driving from Texas to Riverside to be with my family the first week of January, available for pickup then?? I will be your 2010 goat if needed!!
Our Engineer told us that they will probably fit. We are getting a tester to come in next week for the final test. So we are hoping it will be good to go! I will update this as soon as we get the go away!
Any update on this? Still in SoCal area, leaving for Texas this weekend.
Yes, so that U bracket that you receive with the Pods. If you flip them it will make them sit lower on the bracket. Most people don't know that trick but after that, it sits super low.
lindwlson982
