Charles4x4
Only one update:
I spoke with John at Unichips. He confirmed the product below will work for a '06-09 4Runner:
Unichip - 2006 Toyota Tundra tuning chip | car tuning
2006 TOYOTA TUNDRA 4.7L
Add's up to 25hp & 25ft-lb
Easily plugs into the stock ECU & ECU harness in minutes , no programming necessary
Realizes the full potential of Aftermarket add-on's like Cold-Air-Intakes & exhaust systems , as each kit comes pre-mapped for the exact set-up of each car or truck.
No end-user tuning necessary , just plug the kit into the car & you're ready to go.
Easily upgradeable for future add-on's.
Each kit comes with two maps : a low octane performance map & a high octane performance map, switchable from within the vehicle.
Fully tuneable by a Unichip Custom Tuner for customized add-on's . This basically means that the Engine Management System in your ride is now as tuner friendly as the most advanced Standalone systems in the world , without sacrificing any of the factory features. This feature is unmatched by any reflash-tuning or other similar product.
Plug 'n Play harnesses are fully Flux capable - purchase Flux when you purchase the Plug 'n Play kit or upgrade later - Flux simply plugs into the Unichip Plug 'n Play harness.
Plug 'n Play kits are removed from the vehicle in minutes , returning the vehicle to stock tuning , without leaving a footprint of ever having been modified (a feature which reflash-tuning cannot match).
The Plug 'n Play kit that comes pre-mapped to optimize your bolt-on accessories
Installs in minutes, ready to roll!
$525.00 USD
Reviews:
UniChip Performance Chip Engine Tuner | Tundra Headquarters Blog
http://www.toyota-4runner.org/4th-gen-t4rs/160628-who-has-used-unichip-their-4runner-2.html
Reviews are all over the board... Any opinions? Do these chips actually work?
OR...
Do I just stick with this instead and save some $:
https://www.urdusa.com/urd-maf-sensor-calibrator/
Wonder if both would work together?
$525.00 USD
Reviews:
OR...
