4th Gen BL LIFT ANYONE? Help.....Need more inch's
TALLTOYHI
Looking for some infomation on a 1-2" Body Lift for a 2003 Runner Limited V8/ Self Leveling Air Ride. Has anyone here put one in I did find one online from 4Crawler, is it a good kit and are there any others on the market. I'm looking to go a bit taller here as I am running factor 17" Wheels and would like to fit some new DC-1's under it but the 17 X 9's will push the tires out another 1.5" and rubbing will become and issue? Looking for any advise on getting a few more inches installed. I would love to rip out the air ride and go with coils but, I think that's a bit expensive??
PS: UCA replace the OEM or not to replace I have had no problems yet?
2003 V8 Limited Air Ride/Self Level
3" Cornfed Spacer Lift Front
2 1'2" Modern Motors Custom (CAN) Lift Rear/with Air bags
BFG A/T 285/70/17
TALLTOYHI
4Crawler makes good lift kits. I personaly prefer suspension lifts over body lifts, especialy if you are off roading in rugged country. I removed my stock XREAS just so I could install the OME 3" springs and coils. No UCA replacement required. Been really happy with it ever since.
I only installed my 1/2" body lift to increase the clearence between my winch bumper and body.
Well thanks for the reply the body lift was just to get another 1-2" in the looks department as it does not hit the trails off road. I have a great shop here which did the cutom work on the rear end and they suggested it. My only question is.. is it worth to spend the money doing it for an extra 1"..........Or just go for it and rip out what I have already and go with coil in the rear and some coil overs in the front instead of the spacers? I think it's about topped out in the sup lift department without going hard core and tearing out what's under it right now......I have seen some good looking units 5-6" Lifts on them on the site but, one was a 2WD and the other unit looks to be 10"s of thousands sunk into it?
4CRAWLER? Can you move the front bumper up to the so it looks OEM...location after the install? I don't really want a big gap between the body and the bumpers? Any brakelines to deal with or anything that may have to be relocated? I do have a 3" Spacer lift already..........
Anyone attempted to take out the 4runners self leveling system?
TALLTOY
