4th Gen Eibach Pro-Truck Lift Review
Just like Justinbuckley I'm looking at these for my 03 with ~150k.
This kit sounds pretty good and is on sale at TireRack right now.
gimlithepirate, what spring did you put in the rear? I like that this comes with the fronts but figure probably worth replacing the rear as I will also tow camper with this.
Lastly, I assume you put new upper mounts on the front?
Thanks!
I used a SwayAway coil because someone on the forum was selling one cheap. I resold the springs from my Eibach kit locally so the upgrade cost me like 25$.
The SAW coils are pricey. I'd probably just do a Toytec Superflex rear if I didn't find a deal.
I'll ask just in case but I'm assuming this isn't the best option: I also have a 2012 FJCruiser with about 90k miles. Suspension on it feels great still.
Would there be any good reason (if possibility) to swap that over to the 4runner, and save the upgrade $$ for the FJ?
FJ Cruiser and 4th gen are identical except for a few very specific elements. Suspension should be 100% identical.
My 0.02$: If the FJ is your crawler, swap this over to the 4runner and buy Dobinsons long travel for the FJ.
Apologies in advance, I do not mean to hijack original thread... but anyone else think that Eibach Pro-Truck rear coils are a little too short and replaced them with some taller coils?
Long-term on the Eibachs
Considering the Eibach Pro Stage 2 with additional weight leveling in the back -- I haul cargo and pull trailer. Appreciate some feedback from you guys that have been running the Eibachs for a while
265/65 r17
Would this size look bad with the Eibach lift? Have front leveling spacers on now. This kit would add an inch in the rear, the front is adjustable so could leave it at that height or add inch to level. Tires are new so cant upsize those for awhile. Just dont want it looking goofy tall with that tire size and I cant find any pics of this situation. Thanks
I think it would make the tires look small honestly. For perspective, I went from 265/70r17 to 285/70r17's about 6 months after I did the Eibach lift, even though I had just bought the 265's. I just wanted to take advantage of the extra height and fill out the wheel well's better
2001ATL
