TeryT
Here's something that might interest some of you. I had recently installed a tranny temp gauge & auxilary tranny cooler/fan. I was getting funny readings when the gauge read around 200 degrees, and when I would turn the fan on & off. The gauge & fan are two seperate systems, with seperate fuses, grounds & wiring. I noticed that the digital gauge would start reading wildly varying temps when I either turned the fan on or off.
So I began to suspect a grounding issue. In checking where I had grounded the gauge & the switch, under the dash, I found there was about 6 ohms resistance between this ground bolt & the negative battery terminal. I then checked from the body grounding right beside the battery, and still had over 5 ohms resistance.
Upon checking the engine, I found the engine had 3 ohms resistance between it & the negative battery terminal. None of this seemed right, as there are straps that are supposed to ground the engine, body & negative battery terminals together -right!?
So, I ran a wire from the gauge sensor ground, up under the dash, directly to the negative body terminal. Now I get readings between all grounds (battery, body & engine) of under 1 ohm.
So you might check with a digital ohm meter to see resistance between your negative battery terminal & the body/engine. My thinking is that the resistance should be negligable - under 1 ohm. Sensative electronics, such as my tranny gauge, could be effected. I'm wondering what else might be effected as well - trip computer or JBL digital stereo perhaps?
I will report back when I take her out again & see if the new grounding wire helped the wierd tranny gauge situation.
Thoughts?
Thoughts?
