4th Gen Helpful DIY Videos
Stuck CAPS
Suspension:
Coilover Disassembly Without a Spring Compressor (Tacoma)
Adjusting Upper Control Arms (Tacoma/Tundra)
Rear Lower Control Arm Installation (FJ Cruiser)
Spacer Lift/Leveling Kit Installation
Engine:
V6 -
Spark Plug Installation
Mass Air Flow Sensor Cleaning (FJ Cruiser)
Oil Change
V8 -
Timing Belt Disassembly (Tundra)
Timing Belt Disassembly - Part 2(Tundra)
Timing Belt Disassembly - Part 3(Tundra)
AFE Air Filter Install (Same Method to Replace Air Filter
Both -
Homemade Snorkel (Land Cruiser)
Driveline:
V6 -
V8 -
Transmission Fluid and Filter Change - Part 1
Transmission Fluid and Filter Change - Part 2
Driveline Service
Wheel Spacer Install (Pickup)
Both -
Front Brake Replacement
4x4 Front Hub Assembly Replacement
Power Steering Rack Replacement - Part 1
Power Steering Rack Replacement - Part 2
Exterior:
Front Wheel Bearing Replacement
Rear Bumper Reflector Replacement
Rear Blinker Light Replacement
How to PlastiDip Front Emblems and Grille (Maxima)
Backup Camera Install - Part 1
Backup Camera Install - Part 2
Rear Quarter Window Replacement
Rola Roof Basket Install
Windshield Replacement
Interior:
Cabin Air Filter Change
HVAC Control Removal and LED Replacement
Door Panel Removal
Zero-point calibration
Map Lights Turn on with Open Doors
iPad Mini Dash Install
Door Panel Removal
Reset Maintenance Light
LED Map/Dome Light Install
Audio:
Stock Radio Removal
Speaker Replacement
"GTA Car Kits" AUX Input Install
Misc:
Myths About PlastiDip
In threads where a different car/truck is used, the process is pretty similar, if not the same, but make sure before trying, to check the possible differences in the processes.
Feel free to add to this list. I was just bored so I decided to browse YouTube to provide whatever help I can.
Great idea, [MENTION=89415]Stuck CAPS[/MENTION] . Can you organize the first post by catergory and add all the vids that people are posting to post #1. Like maybe suspension, engine (then break that down into v6 and v8), driveline, body work, electrical
I dunno, just general stuff like that.
Was thinking that, just was waiting for a few more vids.
Edit- Done.
Ambrose67
