4th gen Left & Right Heated Side View Mirrors
A/V1
Hey guys. I've got a pair of 4th gen Left & Right Heated Side View Mirrors. This is for the glass only (no housings). I'm selling because I installed some MUTH signal mirrors.
Again, these are the heated ones. Powered with the defrost switch so no additional switches to install.
Great upgrade to your truck! Only $45 for the pair SHIPPED!!!
Inbox is full.
Tried sending you a PM, but your inbox is full.
Will you also send the wiring? Muth sends their kit with all necessary wires and hardware, I assume you used your existing stuff.
Thanks,
Stan
Yeah, sorry about the whole inbox thing. I went through and cleared out a bunch.
No wiring is included with the mirrors. The Muth mirrors didn't include wiring for the heat since it wasn't an upgrade (mine already had it). They plug right in for the factory heat, but I did have wiring to run for the turn signals. Fortunately, Toyota didn't use a wacky connector for the heater terminals. You should be able to get some wiring and terminals from Radio Shack (or even Wal-Mart) to do this job. The terminals are the smaller disconnect type (possibly terminal # 64-044 from RS).
Do our 03' limiteds come pre-wired for heated mirrors? Or do they allready come with them standard? Im not aware of this- anyway to tell if I got em?
You probably already have them as I believe they were standard on the Limiteds. Just pop the glass off and check.
Once again, that's only $45 SHIPPED! I can't believe nobody's jumped on these yet. Pretty easy to wire up, and if you were to buy these from the online dealers, they are $65 EACH SIDE.
