4th Gen - Rear Ground Point?
I don't know if its the "best" spot but I used the rear seat mounts since I mounted my amp behind the seat. I've never had a ground problem and the length of the wire is only 8"...unlike real-life, shorter is always better...:)
i like to keep my amps hidden, u cant even tell if i have amps running until u look under, this is what i did on my 96runner too, also i want to use the whole trunk area with a flat space wen the seats are fold down, to i can maxout my cargo space wen needed.
well i agree on security reasons, but you are already attracting attention with that screen. as for cargo space you have a box sitting in back so the amp wouldnt take up any more room if attached to even the back of the seat. its a clean install from what i can see, i just worry the amp wont keep cool and start cutting out on you.
these amps are good amps, it gets warm, but never hot, i drove 2+ hours with music blasting and it still warm, cant go wrong wit the jl audio amp, plus my other kicker amp thats pushing the rear doors, has a fan built in so its kool, rememeber im doing 150watts per door, and its a/d/s/ 346is in the front and 336im in the back
