4th Gen Speedometer Calibration?
dwm2112
I am looking into the future when the stock Dunlops go thin and need to be replaced. At that time I am likely going to go up in tire size. Is there a method or process for recalibrating the speedo for this in the 4Runner? In my Jeep it is a simple gear change out that take minutes and I am hoping the 4Runner is something just as simple...
That is pretty sad on Toyota's part. They build a SUV that they know will be modified yet they don't have a way to recalibrate the speedo for larger tires which is among the first mods most make... I am surprised..
I just received the new Performance Products catalog in the mail yesterday. Inside were 2 different speedo calibrators. They looked like you plug them inline with the speed sensors and it fixes revs, shifting points, and speedo. I don’t have time right now to look it up on their website, but I’m sure you can find it there for more info. The catalog does state that they are new items. I believe their website is www.performanceproducts.com Hope this helps and I will get back with more info, if needed, later on.
Been thinking about the calibration by the TRUSPEED....
If you're looking to upsize by many sizes then this gizmo may be well worth your money.
If your gonna go from 265/65/17 to 265/70/17, possibly not.
Here's why:
265/65/17 is basically a 30.56 inch tire
265/70/17 is basically a 31.6 inch tire
Speed is calculated on circumference (C) of tire, right?
C= 2*(pi)*radius or Diameter*(pi)
So,
C (circumference) of 265/65 is 30.56*3.14= 95.9584 inches
C of 265/70 is 31.6 *3.14= 99.224 inches
There is only a difference of 3.2656 inches. Therefore, each revolution of your new tire only makes you go 3.2656 inches further.
Percent difference is (3.2656/95.9584)*100=3.4%
As it has been mentioned in previous posts at each speed your going 3.4% faster than it is showing.
100mph = 103.4mph
70mph = 72.38mph
60mph = 62.04mph
30mph = 31.02mph
15mph = 15.51mph
For the price of $81-$184 how many of us really care about the change in speed or change in odometer? Now, if your changing gearing or getting some monster tires, I'd be first in line. Another item to keep in mind is the chart, in the pdf, Doodz gave a link to. For each given diameter or circumference there is a range. The shown range in the pdf was 30.5 to 31.5, then 31.5 to X. The first choice looks close to what your already working with. They claim a 1% close to true, maybe by getting the calibrator you can knock off 2.4% of the error.
Hope this adds to the discussion...and no, I'm not an engineer.
G3 Trout Runner
$190 for what? I can keep those numbers in my head and automatically adjust accordingly. As an added bonus, your mileage will be off so your warranty will last longer. :happy bda:
Hi all,
I’m new here, but have been lurking here for a couple weeks. I’m buying a 05 V8 Limited as soon as they are available.
For less money you can get a Garmin GPS unit that will give you exact speed and many other types of data, including max speed, time stopped, average speed, etc. If you’re willing to spend more you can get turn by turn voice directions. You can get the basic unit for $100. Works great!
The Garmin Que3200 is a portable PDA and color GPS unit with voice ($400). Check it out!
http://www.garmin.com/products/iQue3200/
Koz
toyotadoodz -
i'll be interested in pics of your 4R with the new tires. I'll probly be getting new ones some time soon and would like to see how yours look and how they ride.
thanks.
ToyotaDoodz said:
And in big letters "SuperLift TruSpeed Signal Calibrator is not available for 2003 TOYOTA 4RUNNER"
It does state in the Performance Products catalog that it fits 4Runners 1993-2003 2/4WD $184.95. Probably something you would want to call to verify, obviously.
So stupid question of the day goes to me, "what fits the 2003 should fit the 2004 t4r, correct?" Why doesn't catalogs/websites show this?
Okay, I found the second calibrator. It is the Jet Accu-Speed. I couldn't find it on the P.P. website but found this website showing it.
http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=141548&prmenbr=361
It works for 1993-98 4Runner/Land Cruiser and is $149.99
I must have been correcting/editing my post at the same time you were posting:D
Please see my above post for the other calibrator I found.
