4th gen spindles in 3rd gen
Easiest fix would be to put in a Dana 60. Less likely to break than the OEM CV axles and parts are pretty cheap.
:playball:
the biggest issue is with the tie rod bolting location is on the back of the spindle relative to the rotor while the 4th gen is in the front of the spindle
Dude. That is not what moderators are for.
To slow down repeat questions simply reply with a link to the "how to search" sticky.
:bat:
i was kidding. another instance of tone being difficult to convey through text. there is a part of me, however, that feels like this might be a bit of a repeater troll post.
So you're saying it's a direct, bolt-in swap?
Well on 4th gens the UBJ bolts onto the spindle and is pressed into the UCA where the UBJ is pressed into the spindle and bolts into the UCA on 3rd gens. Then all we have to worry about is the caliper, swaybar and tie rod mounting points being on the wrong side for each...
But after that, yeah its pretty bolt on :trophy:
workingwheelswnc
