4th Gen w/ F & R Eaton TrueTrac vs. OEM Open Diff.
MarkinWMich
Application: 2006 SR5 w/ V6 4WD w/factory traction control system. Daily driver. Occasional light towing (less than 2000lbs). Snow, ice, sand, & mud. No rock crawling or hill climbs, except for sand dunes.
130K on the odometer. Looking to do a regear with 4.56's or 4.88's. Not a lot of highway driving, but when I do, it's under 70mph. Spends most of the time around town, under 45mph. Looking for some good, low-end torque via the new gears.
The OEM open differentials have provided good service, but it certainly has it's limitations in deep snow and on the dunes. Looking for a potential improvement in that area.
I like the Eaton TrueTrac/Torsen differential, I have one in my '89 Mustang (modified for autocross and roadracing), so I am familiar with it's potential "quirks" with the rear end grabbing and kicking out the rear end around corners...but that's in a high-powered vehicle without traction control.
What are people's thoughts on using TrueTrac/Torsen differentials combined with the 4th Gen's factory traction control systems?
LSD in the front is horrible on loose surfaces like sand or ice. Horrible understeer. Don't do it.
That is a consistent response from pre-4th gen owners. So, I am inclined to believe this as true. I am wondering if this is the same experience with those 4th and 5th gen owners with all the computer-controlled traction systems. BTW KidVermicious, I am in no way questioning your wisdom on this issue.
what did you end up going with?
I am to the point where i need to regear and want to do it once... not looking for a locker but if it is my only real option i guess it will have to be...
I'm curious too. I have had limited slip (clutch packs) in 2 different vehicles, and an ARB. So far, the only thing I would consider for the front would be something selectable, like the ARB or Ox or? Maybe a Torsen would work well, I just don't know. Controllability for a daily driver with lockers is horrible, especially on slick roads.
I'm running 4.88s on 255/75/17 KM2s and the highway RPMs are around 3k at 80 mph. Great around town though. I had to do gears after destroying my rear end so I geared in anticipation of 35s (which are now sitting in the garage) If you don't plan on going 35s I'd go with either 4.30 or 4.56.
premiumusedautoparts
