FS: 2006 4th Gen 4Runner V8 Overland Build; Denver Burbs; $28,500
SAC-CA-Runner
(TRYING TO FIGURE OUT PICS FOR POST. ALL TOO LARGE. LINK TO GOOGLE PHOTO ALBUM IS BELOW) For sale is my 2006 Toyota 4Runner V8. 256,000 miles (frame/body), 192,000 miles on engine. This 4Runner was built from 2016 to 2019 with the goal to travel all over USA and Canada while living out of it. It was a California SUV its whole life till I left in July 2019, which means…NO RUST! The previous owner put stop leak in the radiator which caused it to plug and overheat the engine on my way to Utah. So in went a used engine with 64,000 less miles. And while I was in there I replaced the stock OEM manifolds with Doug Thorley headers (no chance of cracked manifolds!), new 02 sensors, timing belt, water pump, new radiator, gaskets, Rutech air-pump kit (no more afterrun pump failure!), new AC compressor (AC is COLD! Heat is HOT!), spark plugs, external transmission cooler, starter and coolant hoses. Shortly after Nitro Gear 4.56 gears and an ARB rear locker were installed with new rear bearings, new CVJ front axles and Jersey Hubs front bearing assemblies. It does have some body imperfections as well since it HAS been used offroad and it is a 2006 SUV. The hood needs painted as the clear is peeling. Rear hatch has minor dent and spoiler needs painting. Body has other very minor dings, but nothing major. Overall I’d say 7/10. Interior is in great shape minus scratches to plastic on lower glove box and door panels. But the dash has NO cracks at all! Nothing on this 4Runner has been spared or overlooked. I’m selling it ready to go (all items shown in pictures ARE included). Pack your camping essentials and hit the road!!! NO, I do NOT want to trade. I don’t need help selling (NO DEALERS, unless you want to pay me $10K more than asking). Will only take cash OR your lending institution work with mine. This truck has a clean CO title and is in hand. I’m in no rush to sell so any super low baller offers will be ignored. And yes, I know modifications don’t add to the price of an automobile. But go ahead and build this 4Runner and tell me where you end up! There is well over $45K into this 4Runner, not counting the price of the 4Runner itself nor any of the motor replacement and maintenance items. And this has been VERY WELL maintained. Everyone knows where those prices are at now for a clean west coast 4Runner, so all comments about price will be ignored. Glad you got a good deal here or there or wherever. Will only respond to serious inquiries only. No tire kickers. Price is $28,500 OBO and willing to negotiate reasonably. Please feel free to DM me with any questions and I can send a this mod list and a detailed maintenance schedule. Thanks for looking.
Additional pictures can be found at:
4Runner For Sale Pics - Google Photos
Mod List Below:
ENGINE/DRIVETRAIN: ($5,200 in modifications not including motor replacement and maintenance items)
Toyota 4.7L V8
Engine Replaced at 176,406mi with engine that had 112,000mi
Previous owner put stop leak in radiator causing it to plug and overheating engine on trip to Moab. Have receipt for engine, parts and pics of engine swap for proof. Been running solid since.
Also completed during motor swap: Timing Belt, Water Pump, Gaskets, new Radiator, Spark Plugs, OEM Front 02 Sensors, Doug Thorley Headers, High Flow Cats, new AC Compressor, external transmission cooler, transmission flush and new fuel regulator
AEM Dry Filter (Important first mod!!! OK, maybe not)
Doug Thorley Headers (No more cracked OEM manifolds!!! But sorry CA, unless you “know” someone it won’t pass visual)
Magnaflow High-Flow Cats (Passed CO smog no problem)
Custom Exhaust with Magnaflow Muffler (Nice sound, but no drone)
Front and Rear Differential Nitro 4.56 Gears (Installed by River City Diff in Rancho Cordova, CA)
Front Diff/Transfer Case – Mobil 1 75W-90 Fluid
Rear Differential – Lucas 85W-140 Fluid (Thicker to prevent to keep air locker gaskets from leaking!)
ARB Rear Air Locker (Installed at time of Re-gear)
External Transmission Cooler
CVJ Front Axles w/ Silicon Inner Boots
Jersey Built Front Hubs
RuTech 4.7L Air Induction Bypass Kit
Rear Differential Extended Breather Line (Inside Fuel Door)
Rocksteady Aluminum Windshield Washer Reservoir
SUSPENSION: ($6,000 in modifications not including labor)
Icon Front CDCV 2.5 Extended Travel Coilovers w/ 14” 700 Springs
with UPDATED Top Hats with spacers and bolts (Plus one old spare)
Icon Rear Extended Travel CDCV 2.5 Shocks
Dobinsons C59-331 Heavy Duty Springs (Strongest they make for 4Runner)
Icon Delta Joint Tubular Upper Control Arms (New bushings installed 03/2021)
Total Chaos Stock Offset Uniball/Dual Shock Capable Lower Control Arms (New bushings installed 03/2021)
MetalTech Body Mount Chop
Total Chaos Heavy Duty Alignment Tabs
Total Chaos Gusset Kit
Icon Rear Hydraulic Bump Stops (Inside Spring)
Icon Adjustable Panhard Bar
RESZ Fab Rear Upper and Lower Heavy Duty Control Arms
Wheelers Super Bump Stops Front and Rear
EimKeith Trackbar Relocation Bracket
BRAKES: ($2,000 in modifications not including labor)
340mm - 6 Piston Stoptech Big Brake Kit (Black) w/ Ext Brake Lines (SOS Performance) (BEST MOD!!!!)
5th Gen 4Runner Rear Calipers w/ Stoptech Rotors and Pads
Rear Extended Brake Lines
Motul RBF 600 Brake Fluid
WHEELS/TIRES: ($1,900 in modifications not including labor)
(5) Level 8 Mk 6 17x8 Anthracite Wheels
(5) BF Goodrich K02 285/75/17 Tires (BRAND NEW – Less than 100 miles on them)
Black Locking Lugnuts
TRD Stickers for Caps
ARMOR: ($8,700 in modifications not including labor)
Demello Offroad Baja Style Front Bumper, Includes:
Smittybuilt X20 12K Gen 2 Synthetic Winch w/ Cover and Wireless Remote
Factor55 FlatLink (Red)
Factor55 Hawse Fairlead (Silver)
4x4 Labs Dual Rear Swingout Bumper, Includes:
Baja Designs Sport Flood Lights (Rear and Back Up)
Swing Down Table
5lb Aluminum Propane Tank Holder (Propane tank INCLUDED)
TRED Pro Mounts (TRED Pros INCLUDED)
RotoPax Mounts (RotoPax INCLUDED)
Yakima Lockable Mounts for Shovels (Krazy Beaver Shovels INCLUDED)
Wilco License Plate Relocation Bracket w/ Light (License Plate NOT included…duh)
Waterport Mount (Waterport NOT included)
RCI Metalworks Steel Skid Plates:
Front, Transmission, Transfer Case, Fuel Tank, Rear Differential
RCI Metalworks Rock Sliders
Icon Rear Shock Rock Guards
EXTERIOR: ($6,200 in modifications not including labor)
Prinsu Roof Rack w/ Tamper Proof Screws
James Barroud Evasion Roof Top Tent, Includes;
Hypervent Condensation Matting
(2) 5ft. Luminoodle Lighting w/ Remote
Interior Lighting Wired to Truck
(2) Tepui Shoe Holders w/ custom mounts to allow you to hang them inside the tent
James Barroud Awning w/ Tunnel Attachment
Front Windows Tinted
CBI Offroad Ditch Light Brackets (For CB/HAM Antennas)
LC-80 Snorkel (Sealed to Airbox)
OEM 4Runner Limited Color Matched Grill
DT Moto Blacked Out Headlight Housings with LED Bulbs
Rad Rubber Wheel Well Liners
LIGHTING: ($1,600 in modifications not including labor)
Baja Design Squadron R-Sport Fogs - Amber - Wide Cornering LED
C4 Fabrications 10" LED Hood Scoop Mount
Baja Design S8 10" Driving/Spot LED Bar (In stock sport hood scoop)
Baja Design S8 40" Driving/Spot LED Bar (Front of Baja Designs rack)
S2 Pro Flood Light (Side of Baja Designs rack) w/ Custom Red Covers (No bugs – YAY!)
S2 Sport Flood Light (Rear of Baja Designs rack) w/ Yellow and Black covers
Iggy Corp Rock Light Kit
Baja Designs Under Hood Rock Light (White – Turns on when hood is lifted and side lights are turned on)
Baja Designs Dome Lights (White and Red Under Rear Hatch, For Night Light)
INTERIOR: ($10,800 in modifications not including labor)
Trekboxx Alpha Drawer System w/ Tie-Downs for Fridge
Trekboxx Rear Seat Delete/Platform w Lockable Storage (I do not have stock rear seats)
Katzkin Leather/Alcantara Front Seat Covers w/ Heated Front Seat Kit
Center Console Vault
Autodim Rearview Mirror w/ Compass and Homelink
Perforated/Leather Steering Wheel w/ OEM Buttons on Right (Phone Answer/Disconnect/Source)
Weathertech Front/Rear Mats w/ TRD Off Road Stickers
White Interior LED Lights w/ Switches on doors to black out during camping
Sound Deadening on floor, doors, and hatch
Fire Extinguisher with Under Front Seat Mount
Outer Limit Supply Waterproof Individual First Aid Kit w/ Quick Release Mounting System
Wilco Quick Fist Mounting Brackets w/ Quick Fists for Ax (Ax Not Included)
New Interior Carpet (Installed early 2017)
STEREO/ELECTRICAL: ($2,300 in modifications not including labor)
Auxbeam 8 Switch Unit
PowerTray and PowerBlock
Interstate Batteries Group 27 Battery (BRAND NEW – June 2021)
Pioneer Head Unit AVH-2300NEX w/ backup camera
Alpine Components (Front) and Coaxial Speakers (Rear)
JL Audio JX400/4D 4 Channel Amp
Rockford Fosgate Mono Amp
JBL Enclosure with 8” Kicker Sub
Icom 2730A Ham Radio with dash mounted faceplate, external speaker and antenna
Midland CB w/ Firestik Antenna
Blue River Systems 12 Port Rear Fuse Block in OEM Jack Area
ProClip Phone Mount with Arkon Phone Holder
VSC Disable Switch (For playing in the snow and mud!)
MISCELLANEOUS EXTRAS (INCLUDED WITH PURCHASE): ($1,000+ in extras)
ARB Air Compressor w/ ARB Hose and Wits End Air Pacifier
TRED Pro Recovery Boards
(1 each) RotoPax 4 gallon fuel; (1 each) 2 gallon fuel and water
Krazy Beaver Regular and Mud Shovel
Firestik 7ft Flag Mast w/ PVC holder on edge of rack (for those sand dune trips!)
Spare Front Axle (NAPA Brand)
Extra OEM Toyota Oil Filters and Plug Gaskets
Container of spare parts/bolts/washers/etc
Spare Fluids/Touch Up Paint/Etc
Windshield Sun Shade
Trailer Brake Controller (Came in the car but took out)
erinobr2000
