4th Gen Wheel Swap
bgibbs11
I think this may have already been answered somewhere, but I can't find the answer. I have a 2004 4Runner Limited, V6. It has stock 17" rims on it. I wanted to know if I'm able to swap those wheels/tires with a 2007 4Runner Limited, with the 18" rims/tires. Both are stock wheels/tire sizes. Logic says they should fit, am I overlooking something? will I be ok going from the 17 to 18 with absolutely zero modifications? Thanks in advance!
Yes. Rim size doesn't really matter as long as the outer tire diameter doesn't change and the backspacing is the same.
That being said you can also fit larger tires in there, depending on width and diameter, if you want with no modifications needed.
DionicioLives
