Well for starters I have been reading for hours its now 4:15 am and I havent found any hint on what the issue is.
It is a 2000 sr5 auto 2wd
What it is doing is running like total crap. It runs vary lean gives me a code for bad down stream o2 but I know thats not it. Fuel pressure reg is good new fuel filter good fuel pressure, clean MAF, working TPS, all 6 cylinders getting a good hot spark. It starts fine and thats it. From a cold start in late afternoon in the sun it acts like its -20 out and wont down shift when its in 1st with O/D off, after it gets hot it runs better. It revs slow in N about 6 to 7 seconds to 3500 and around there it sputters and when i try to give it the go peddle it drops down to 2000 rpm some times it makes it to 4000 and right at 4000 it has epic power and goes all the way up to red line no problem.
It does have the stock timing belt, that is on my plans for next month, could the belt have stretched enough where all the low end torque is gone by the way it hasnt skipped a tooth but i can check again. I am leaning to ecu wit it always running like new right at 4000rmp
Any ideas
and 147k miles im stumped :ybrick:
Any ideas
