Master Yoder
I have never owned a SUV or truck with 4WD so I am not very familiar with it. I have a 2002 SR5 Sport if that makes any difference.
I read on a web site that you can switch to 4WD as long as you are under 60 mph, is that safe to do or is it better to stop first if you are able to?
What are the main differences between low and high gear 4WD? I would assume that low is when you are stuck deeper in snow or mud and it is harder to get out but are there certain speeds that you should be in low gear and certain speeds you should be in high gear?
If the roads are snowed in do you drive in 2WD whenever you can and only go to 4WD if you start spinning or is it safe to drive in 4WD long distances when you are in a situation that "could" get slippery etc. like the roads have a lot of snow on them but you can drive in 2WD for the most part.
How do I tell if I have differential locking, what does that do exactly? I have a button that light up a VSC light when I am in 4WD mode but I don't really know what that does actually other than it is Vehicle Skid Control.
One other thing I noticed is when I move the stick from high to low it seems pretty tight, is that normal? i guess it prevents you from accidentally going to low while you are driving.
Sorry for all the green questions, I have been wanting to get a good SUV for a long time so i am glad I was finally able to.
