imryannn
So after i crasehd, my battery kept dying from it sitting, and it was parked between cars so i could pull it out to jump it because i have this magnetic strip security thing that you have to swipe across another part for you to start it or put it in gear, so i was trying to figure out how to pull my car out, and my friend was like just put the 4WD in neutral and ill push it out...so i did that. so i pulled it into my driveway next to my brothers car, and it ended up dying again, so i had another friend come help me jump it, so i did the same thing, put it in neutral and rolled backwards until my hood met the other cars hood, after i jumped my car, and let it sit there running for a little while (note: the 4WD is still in neutral, and the car is in park at this point), i go to pull back up the driveway, and it goes no where since its in neutral on the 4WD shifter, but when i put the car in its neutral gear to get back into 2H, i do what i have always done, but this time i got the shifter between neutral and 4H, and then it would grind one something, and it wouldnt let me re-engage in 2H...
what did i do wrong, any help please?!
