DarkTiger,
Hydroplaning is not due to the vehicle itself per say. It is more about your TIRES. If you buy good, high quality tires, then the risk of hydroplaning is much less. (Of course, being a SUV, the 4runner does not have the same dynamics as a car.)
Good, high quality tires: Michelin Cross-Terrains, Bridgestone Dueler H/L or AT REVO, Goodyear Fortera, Michelin LTX M/S, etc..
As i stated in your previous thread (4x4 vs. 4x2:
http://www.toyota-4runner.org/showthread.php?s=&threadid=1221), at highway speed, the MOST important safety feature on your 4runner is VSC (stability control), NOT traction control. Traction control (ABS pulsing the slipping wheel) is NOT very effective at high speed...in most cars, the computer decreases traction control intervention at high speed (Land Rover shuts it off above about 40 mph). Why?? Because it may cause sudden shift in driving dynamics that may surprise the driver...in addition, MOMENTUM is the main thing when you go at high speed.
Because of momentum, VSC becomes ever more important. VSC will brake the appropriate wheel to correct/prevent OVERSTEER or UNDERSTEER...basically, VSC prevents a spin-out (oversteer) or you jumping off a mountain road at a sharp curve (understeer). VSC computer may detect this BEFORE you are even aware of it. That's the beauty of it!
VSC uses the ABS sensors, along with your steering wheel angle and G-sensor to determine the correct path. It will then use it's 4-channel ABS system (standard on all 4runners; thus VSC is standard) to pulse the appropriate wheel(s) to help you steer in the proper direction. VSC will also de-throttle you to cut engine power...thus, cutting momentum, allowing you to steer easier.
VSC has also been proven in a recent CONSUMER REPORTS article to PREVENT roll-overs! Another great side benefit!
So, to your original question, TIRES are the most important thing in preventing hydroplane. However, VSC is the most important safety feature to have at highway speed IF your tires fail.
And if your tires and VSC fail, then let's hope that the airbags work as advertise and that your Toyota engineers designed the 4runner's body well!
Hope this helps.
P.S.: For more info on VSC (stability control), please see this thread:
http://www.toyota-4runner.org/showt...?s=&threadid=12
(Just scroll down)
