4x4 driving question from a new guy
jetman1979
My wife and I went to get our free oil change in her 05 Highlander and drove out with a 2010 SR5 silver 4runner 4x4.
I am not new to Toyota as I also have a 2010 Tundra double cab with the TRD package. I love that truck with its 5.7 engine. However this is my first 4x4 so I have a few questions on driving one from the experts.
Question 1 can I use 4hi on dry pavement. Here is why I ask being a kind of guy that cant wait to play with his toys I put it in 4hi on the street but when I made sharp corners it did not feel right.
It felt like a tire was not turning at the same speed and felt alot of resistance.
The owners manual only says to drive about 10 miles a month to keep things lubed up.
I did not drive it very long with it in 4HI till I got an answer from why it feels like something is binding up going around curves.
Look forward to hear from you guys on what I am doing wrong.
Mostly no. Can be used sparingly if necessary, the less turning the better. Relatively straight is fine for short periods so the 10 miles per month isn't a problem, though if it can be done on dirt, that's even better.
Welcome to T4R.org.
The 4WD system in your 4Runner is a part-time system, so both the front and rear axles rotate at the same speed. On a high traction surface, there isn't any slippage on the wheels to allow them to rotate at different speeds through a turn causing the driveline to bind. You can drive on dry pavement as long long as you're going straight.
yes bind
Yes that is what was going on as I was going around the curve. It felt like there was a wheel binding up and I really had to mash the gas. I will not do that anymore since I dont want to tear up the transfer case or drive shaft.
I guess I will only use the 4 wheel option when it is snows (not often in Texas) or in the dirt.
Thanks for making it clear on how the system works.
