Ok, I know you're all thinking it... But the real question is who's going to do it first!? Doesn't sound like a SC is going to be an option, so why not a 5.7 swap. I wonder if it would even be possible....
Toyota put the tundra 5.7 with the TRD S/C into a tacoma few years ago for sema.
Seems like the 4.6 1UR-FE would be a better choice...
How come? 271hp and 313 ft/lbs vs 381hp and 401 ft/lbs. Gotta hack the car up to fit it in no matter what. And I'm sure either way you'd have to run a standalone or do some something. I know the factory tundra ecu runs the gauges and crap... Is the 4runner the same way?
Thats just it, you shouldn't have to hack up anything, as the Prado 150 chassis is made for the 4.6 V8 in the GX460.How come? 271hp and 313 ft/lbs vs 381hp and 401 ft/lbs. Gotta hack the car up to fit it in no matter what. And I'm sure either way you'd have to run a standalone or do some something. I know the factory tundra ecu runs the gauges and crap... Is the 4runner the same way?
I'm sure there are plenty of the unloved 4.6 Tundras around.
If I was to do a v8 swap it sure the heck would not waste my time and money wth a toyota motor.
A Chevy LSX V8 swap would be the way to go. It would cost you 1/4 as much and make 5x the power. Lsx is pretty much the defacto v8 swap for any platform (yes even ford fox bodies now commonly run lsx motors). You just can't beat the price, reliability, or power to weight ratio (it probably weighs less than the stock 4.0 v6 motor we have now). I know there are other generation land cruisers and 4 runners with them right now. I'm sure someone will eventually make a swap kit, but there is no demand at the moment. The mechanical side of the motor swap is cake, the electronics integration in newer cars is the hard part. Then all the other parts failing under all that new found power would be the next issue.
Here is a few vids I ran across in 5 minutes of searching.
https://www.youtube.com/watch?v=nHzYXiSMuu4
https://www.youtube.com/watch?v=LbmgeDCYlcs
https://www.youtube.com/watch?v=A_0fiYB8rko
You can find lsx motors in just about everything. RX7s and miatas are common.
if your going to go that deep into it ...
Why not put one of toyota's 4 cylinder or V6 turbo diesels into it instead???
But 1uz-fe are stupid easy to swap... seen them swapped in older Toyota cars with only 8 wires.
