shawnstcyr
I made this from a few simple parts, picked up at my local fastener store.
Picasa Web Albums - shawn - ARB HILift Mount
Nice work, now paint that hood!
Yeah, it looks bad. That costs $800 to fix. Believe it or not, it started as a small chip in the clear coat. Then I drove it 13 hrs through HEAVY fog from Denver to Abilene, Tx. When I got home the entire hood was severely wrinkled. I had no idea fog would do that to you at 70 MPH! It has since dried out and shrunk, but it looks awful.
I think it looks like lightning!
does the red on the hood distract you though? I would think that if that was in my view it would mess with me all the time.
The top side mount is the wing nut with a washer. Another nut would probably not be a bad idea here also. But I was looking to make it "tool free" for removal, and easy to get at in case I need to check the oil or something under the hood.
While at the hardware store I also entertained the idea of using some garage door track mounts to make a bump forward so the Hi Lift would not interfere with the hood. But I was trying to stay under $10 like the Texan showed me....
I am now changing out the driver's side 4" bolt for a 5" so any moisture that gathers can run down the Hi Lift-away from the base and will allow me to keep the base in place without rubbing against the top bar of the ARB bull bar.
Also not shown is 2 little rubber caps to protect the tops of the bolt threads. Easy to pop on and off-had em laying around the garage so figured why not?
The Texan wants to know if that shiny spot on the front of your jack is from his lift install :0 Good job, Ron. A little overkill, but that's just how you roll!
I prefer to have the friction of the 2 nuts working against one another to ensure no movement.
