5 speed transmission fluid info
jeober
I am planning to do a WS-ATF flush when the weather gets warmer. However, I wanted to share this particular information now regarding the fill and overflow ports on the transmission. It's a bit different than expected. See below:
I have now 16L of WS fluid for my flush. This stuff is obviously right from Japan and not cheap. I made a bit of a deal for this with dealer service. Expected to pay about $41-51/container depending on the discount you can swing.
How does the manual say to drain it? Drop the transmission pan? Any plan to get the fluid out of the torque converter and cooler? On my last car I did a drain and fill, drove around some, then another drain and fill. Does not get all the old fluid out, but replace a good bit of it.
WOW that is very different from the standard way. The picture explains it all. What one would assume is a drain plug (on the bottom of the pan) is actually not a drain plug since it has a well/tube inside the pan housing. So the only way for the ATF to be drained is to remove the pan.
On my 2003, I just removed the bottom pan plug and it drained nicely. Obviously there has been a design change!
yes, greasefinger,
what one would assume is a drain port is actually the overflow port. There is a standpipe in there. I was totally surprised and I wanted to alert this. Using the fill port for overflow would have been a big mistake. Look how high it is.
Dropping the pan is the way to remove. I do plan to pump out the pan fluid though the fill port with a hand pump, if this works, as the first step to my manual flush procedure.
I also need to verify than the trans cooler return line empties back into the pan. If so I can add fluid back this way rather than through the fill port using 2 L liter increments of the manual flush.
