5100's and daystar 1.5" rear lift.
Bohicagain
New to the 4runner mod and decided to lift the wife's 4runner. Not a mechanic but know how to look at you tube videos.
Maxed out the 5100 in the front with a 1.5" daystar in the back. The front is .5 inches lower but figured the rear will settle down as time goes on.
Made a how YouTube video. The front video came out good but the rear no so much. Helper had to go so wife helped and let's say it wasnt martial bliss putting the coil back in.
Time to get an aligment.
The rear will definitely settle. When I first installed this setup I thought the rear was way too high, but after a few thousand miles it's pretty much dead-level.
I think your rig is dead level.
I went top notch in the front on my 5100s and a 2" spring lift in the rear and I was running 0.5" positive rake. So, if you did a 1.5 spacer, you should be perfectly level.
It looks pretty badass!! I'll be doing the same setup this weekend. Do you have the link for the video you made?
