Fred MaN said:
My dealer says do NOT tow in 5th gear (od) ........ but on the hiway in forth at around 70mph im pulling like 3 to 3,100 rpm I would think this can't be good??
This is Toyota Motor's advice, not just the dealer's. Two reasons for this:
-In fifth gear (OD), the torque converter is much more likely to unlock and run for long periods unlocked. This generates heat, which is bad for the life of tranny components. It also costs fuel economy, as the unlocked torque converter is churning away and generating heat which you have to burn fuel to produce.
-Towing in 4th (or with OD locked out in older 4- speed A/T 'Runners) gives you much better engine braking, aways a nice thing to have when towing.
I tow a 4,000# trailer, and did with my previous '98 'Runner as well. It's easy to learn to recognize when your torque converter unlocks: There's a jump in rpms that's less than occurs if you downshift to 4th. It's about 200 rpms for our '03 V8, and was ~ 400 rpms for our '98. If this happens and doesn't drop back into lock within 60 seconds or so, it's time to manually downshift to 4th. This will let the converter lock itself and begin to cool back down.
If you're diligent about watching for this and are in a situation where you don't need engine braking, running in OD/5th shouldn't hurt anything. I have to admit that monitoring this is something of a PITA. I think it does pay off, though: Our '98's tranny still worked like new at 75K miles and 30K tow miles when I traded it in.
BTW, I agree that 3100 rpms won't hurt a Toyota engine - our '98 ran at 4800 or more for many minutes climbing Interstate grades in 2nd gear in the mountains of V VA.
