5th Gen 2010-2018 Front Axle Seal DIY
Seattle206
Senior Member
Thought I should post it here as this thread is more appropriate and useful here than in the 5th Gen Forum.
My 4Runner is a 2014 with 43k miles, noticed that my driver side front axle seal developed a leak. The front diff seal area and skid plate was soiled with gear oil. I do take it through forest roads, off-road vehicle parks, pools, mud and sand quite often which may have contributed to such an early seal failure. Built up mud, dirt and grit can lodge in there creating a leak. I had my driver side rear axle seal go out a month earlier which cost me new parking brake shoes, axle seal and bearing assembly. Quite costly to repair as I don’t have a 40 ton shop press and specialty bearing tools laying in my garage. Be careful with those seals if you ever do any axle work and make sure your differential breathers aren't clogged! You might be driving around with a leaking axle seal without knowing it. I'd recommend replacing the seal as soon ASAP to minimize the risk of oil starvation to your differentials.
Tried going through Toyota of Seattle and Michael’s Toyota of Bellevue hoping that my repairs would be covered under the 60k/5 year powertrain warranty. Nope, null and void with both dealerships due to "Vehicle is heavily modified in affected areas".
Not sure how many of you 5th gen owners have experienced axle seal leaks but they will happen as these vehicles age. The more you take these things off pavement the higher the chances a leak will develop. The labor is somewhat involved and time consuming but any green shade home mechanic can do it with relative ease. Most independent shops or dealers will charge $200-$400 to replace an axle seal. You can do it yourself for just the cost of a new OEM seal at $15.
I just did the job which took about 2 hours at a relaxed pace.
Front Axle Seal DIY Tools & Parts:
35mm Socket
19mm Socket
17mm Socket
12mm Socket
10mm Socket
3/8” and 1/2” Socket Wrench
1/2” Breaker Bar
Small Flathead Screwdriver
Needle Nose Pliers
Hammer(s): Dead Blow, Rubber Mallet, or Drilling Hammer
Pry bar
Pitman Arm Puller
Torque Wrench rated up to 175ft/lbs
Anti-Seize
Blue Thread locker
Seal Puller
1/2” Impact Driver or Impact Wrench (not necessary but makes things quicker)
2” Diameter PVC Coupler
LH Front Axle Seal P# 90311-47027 or P# 90311-47013 for RH Seal
Inner Axle Dust Shield P# 41336-35020 (if needed)
Hub Grease Cap P# 43514-28010 (if needed)
GL-5 75W-85 or Equivalent Gear Oil
1) Place vehicle on 4 jack stands, make sure surface is level for an even differential drain/fill. Remove tire, front skid, and drain diff. See diff fluid drain DIY below.
2) Use your 3/8” wrench and 10mm socket to disconnect ABS sensor, place aside so it doesn’t get stretched. Unbolt brake line bracket from spindle with 12mm socket. Remove the endlink's top nut with 17mm socket and pull it out the spindle. Unbolting the brake line bracket and endlink gives you more wiggle room to get the CV out.
3) Remove dust cap from wheel hub with flathead and hammer. I destroyed my dust cap getting it off but it’s a cheap part to replace. Remove cotter pin with pliers and wheel hub nut with 35mm socket and breaker bar, my impact wrench made easy work of it. Keep in 4LO if you’re working by yourself or have somebody hold the brake pedal and steering wheel.
4) Unbolt the two lower LCA bolts with 19mm socket.
5) Remove cotter pin and tie-rod castle nut with 19mm socket. Try to hammer out the tie-rod. If stubborn, use the arm puller to get tie-rod out.
6) Use dead blow or rubber mallet and whack the axle face a couple times. Careful not to damage the threads. Use the hub nut as a thread protector. If it’s stubborn, hit with a drilling hammer.
7) Put some muscle in and pull hub assembly out and work out the CV axle. It will come out with enough force but be careful with not damaging the hub's rubber seals. Secure the hub to the side (bungee cords) so it stays out of your work space. Watch that brake line.
8) Have some cardboard or your drip pan as this part gets messy if you haven't drained your diff. Use your pry bar and work out the CV half axle at the differential. If your CV isn’t straight and parallel you will have difficulty getting it out. You can have extra hands hold up the outer CV end as you pry at the axle. Careful not to damage the thin metal dust cap/flange. If you do happen to bend the shit out it you can replace with part# 41336-35020. Once you see the axle pop at the diff, continue to work slowly it until you can pull it out.
9) Examine your seal orientation and take note of how deep it was pressed in from the factory. Try using some digital calipers if you can or get creative. Even take a picture for future references. Mine was flush with inner diff housing from the factory.
10) Use the seal puller and yank the old seal out. Careful not to damage the metal seal housing inside the diff. Now clean the seal housing with a new rag.
11) Grease up your new seal with some MP grease or gear oil. Remember, the “big lip” side of the seal faces out from the diff. Press in the seal by hand. Take a 2” metal or pvc coupler and gently tap in the seal. Tap the seal until it is flush with the seal housing. It took a couple of times to get the seal in properly. Examine and make sure the seal in there evenly and square. If not, you’re going have to pry it out, risk damaging the seal and re-do it. I had to back it out a little using the seal puller but wrapped the sharp ends with black electrical tape.
12) To re-install the CV, have somebody help you hold your CV axle straight and parallel to the ground, makes things easier but with enough experience it can be done solo. Lube up and align splines. Make sure the C-Clip opening is facing down as you insert axle back into diff. Be careful not to damage or dislodge the new seal. Exert a bit of force to pop the axle back in. Might take a few tries but once it locks in, you’re good.
13) Re-install the wheel hub assembly, tie-rod, LCA. Torque LCA bolts 118ft/lbs with some blue loctite, tie-rod nut to 67 ft/lbs, re-insert cotter pin. Re-install endlink at 52ft/lbs and brake line bracket (snug tight). Torque the wheel hub nut to 174ft/lbs. Re-mount ABS sensor.
14) Re-install wheel and torque to 83ft/lbs.
Front Differential Fluid DIY Tools & Parts:
1/2” Socket Wrench and breaker bar
10mm Allen Socket
Torque wrench
x1 90430-24003(Copper) for Drain
x1 12157-10010 (Silver) for Fill
1.50 to 1.60 liters of 75W-85 GL-5 or equivalent (I used Valvoline 75W-90 Conventional)
1) Since you already have vehicle on all four jack stands and skid plate off.
2) Remove fill bolt with 10mm allen socket and set it aside. Remove drain bolt with 10mm allen socket. Drain and replace with copper washer part # 90430-24003. Torque bolt to 48ft/lbs. *Your fill/drain plugs may be seized and you will strip them for sure. The day before you tackle this job, spray the plugs with PB Blaster. Spray again as you begin the job. Heat up the plugs with a torch for 5-10 minutes and give them a few whacks with a ball peen hammer. If you can't get them off even with a breaker bar, try using an impact wrench. Worst case is that your can chisel if off or tack weld a nut onto the plug and wrench it off. The factory 10mm hex plugs are a horrible, and cheap design. Be sure to have your replacement plugs ready and may sure to apply some anti-seize on the threads and around the plug washers.
3) Pump 75W-85 gear oil in until it runs from the fill hole. Replace with silver washer part # 12157-10010. Torque bolt to 29ft/lbs.
4) Test drive a bit and ensure there are no leaks from your from drain bolt or axle seal. Re-install your skid plates.
Evidence of axle seal leak.
Drain your front diff so the job is less messy.
43k miles, black oil and a collection of shavings and nasty bits.
Undo that ABS sensor. Unbolt brake line bracket with 12mm socket. Unbolt endlink's top bolt with 17mm socket and pull it out.
Remove hub cap, cotter pin and hub nut.
Give the face a couple whacks with a hammer. You should put the hub nut back on as a thread protector.
Undo tie-rod cotter pin, bolt and use arm puller to pop off tie-rod. All done with a 19mm socket. I used this pitman arm puller https://www.napaonline.com/en/p/BK_7768071
LCA is held on by two 19mm bolts.
Pull wheel hub off axle and work the half axle out.
Pry axle, careful not to damage that metal dust cap.
Axle pops out of diff.
Set your CV axle aside and clean it up.
Old seal and how it was pressed from the factory. Mine was pretty gunked up.
Use seal puller to pry out seal. I used the Lisle Seal Puller 56750 https://www.amazon.com/Lisle-56750-Seal-Puller/dp/B0002SRCKG/ref=sr_1_5?ie=UTF8&qid=1515453888&sr=8-5&keywords=seal+puller
Sealless diff housing. Clean it up with a new rag.
Use some gear oil or MP grease to lube up new seal.
Push in new seal by hand and use 2" coupler to act as a seal driver. Space is tight so get creative.
New seal is on flush. Now re-install everything but be careful inserting the axle back into the diff. Don't want to knock or damage the seal. Remember that the c-clip opening faces down when you insert axle.
Re-fill diff with new oil.
5th Gen Torque Specs from the Factory Repair Manual:
Update:
Drove over 350 miles since I replaced the seal and no leaks. Did some washboards and mud trails over the weekend. Washed and hosed everything down. Dry diff!
[MENTION=117117]Seattle206[/MENTION]
Fantastic Write Up!
I have had both front diff seals go but they were replaced under warranty.
It has been a thought in the back of my mind though that once I am out of warranty and I do go off-road as much as my life permits I will be looking at replacing them again.
great writeup, and amazing pictures!!
This should be very helpful for others. Thanks for taking the extra time to write this up.
Useful/good write up.. One thing though. On "Pry axle carefully..."
I would not recommend that... too much potential for damage. Instead you can see the factory removal tool marks on the inner CV housing in your picture. Just get a punch... and use a hammer to knock it out from there. Eliminates the potential for damage and allows you to get some shock loads on it which helps it to release.... sometimes it help to spin it around and hit it on a few spots.
Great writeup. I went through the same process replacing the needle bearing right behind the axle seal. You can actually leave the cv connected to the hub and still have clearance to pull the cv from the diff and dangle it out of the way. Its a little more cramped but can save some time. I used a punch and hammer on the indentations to pop the axle out of the diff. One trick that made it really easy was rotating the axle 1/6 of a rotation at a time until the clip holding the axle is in the right position and it takes barely any force to knock it out. When putting the axle back in I oriented the clip with the open side down and held in place with a dab of grease and it slid in pretty easily.
Bookmarking this to my "4Runner Maintenance" folder for future use. Thanks for taking the time! :thumb3:
Front axle seal replacement
Thanks for the tutorial. Wow!
:first:
This is a good write up with great photos. I think you went to a lot of effort to get those pics, since both hands are in some of the shots.
:juggle:
I feel like I could do this now if I have to. Most of the cost is labor so this offers a substantial savings. It helps me to do this work myself so I understand how to fix it when something breaks. Good tip on the brake line disconnect. I broke one when I did my lift install and it cost me $87 for the part.
I'm not sure but I think occasionally people have to replace axles and boots in the field when they break. Knowing the tools and work involved could save you if you're stuck off-road.
Fantastic write up!:thumb:
I noticed both sides were leaking last weekend when I was tinkering around underneath. 131k miles and they were bone dry when I lifted it last month. Any idea why both sides would start leaking at the same time?:shrug: I checked my front diff breather and it didn't appear to be clogged up. Are the diff breather caps supposed to be a little "springy"? I popped open the front diff fill port to check the level. It took one solid pump of fluid and was flowing out again, so I know it hasn't been leaking for very long.
I went ahead and ordered the seals for each side along with new axles. I know it's only a matter of time before my CV boots/joints fail. I'll keep the old ones around as a spare.
Thanks to [MENTION=117117]Seattle206[/MENTION] I was able to swap both axle seals and while I was in there I swapped out both CV axles. I used the Cardone Select HD axles as they supposedly use the same CV boot material as the OEM boots. These were $70ea. from RockAuto.
I was able to pull the axles without separating the tie-rod. This was very tricky and very tight, but it can be done. I loosened the bolt/bracket securing the brake line and this gave me a little more room. I had the entire front jacked up, and left the 4Runner in the "on" position to unlock the steering wheel. This let me move the hub around a little bit more.
I used the same 2in pipe coupler to seat the seal and that seemed to work perfect. It doesn't need a lot of force, so a small hammer can be used to lightly tap it in.
The bad news.... I may have over-seated the passenger side seal. After a short drive last night (20 miles), everything was completely dry. After running around town all day today (100 miles), I popped my head under and there was a drop of gear oil sitting just under the seal. I'm hoping it's just extra gear oil from when I lubed up the seal for insertion, so I cleaned the area with brake cleaner and will keep an eye on it. The FSM lists a pretty decent range for the passenger side seal to be seated, but given the design the seal can easily be pressed in too far.
DJNutshell
