5th Gen Brake Upgrade and CV Axle + Part Numbers
88Center
Member
Doing a bit of maintenance and figured I'd put all the part numbers and notes in one place. Toyota has updated many part numbers. These are accurate as of 2026.
CV Axle Notes
CV Axle - 5th Gen Parts
OEM Boot Kit, Front Drive Shaft In & Out Joint, Right Hand
04427-60133
(replaces: 04427-60132)
OEM CV Axle Shaft Assembly, Front Drive
43430-60083
OEM CV Axle Flange Nut
90177-A0023
35mm socket required
CV Axle - 4th Gen Parts
OEM CV Axle
43430-60062
(replaces: 43430-60061)
04427-60142
(replaces: 04427-60141)
1 boot kit per axle.
90178-28002
(replaces: 90179-28007)
OEM Front Wheel Adjusting Lock Cap
43525-35010
OEM Cotter Pin
95381-04045
CV Axle - Associated Parts
OEM Type T Oil Seal / Output Shaft Seal
90311-47027 (Left)
(replaces: 90311-47012, 90311-47020)
Fits 1996 to 2024
90311-47013 (Right)
(replaces: 90311-47010, 90311-T0016)
Fits 1996 to 2013
90311-47026 (Right)
(replaces: 90311-47021
Fits 2014 to 2024
The seals listed above are sometimes called Differential Carrier Front Seal, Oil Seal, Drive Shaft Seal, Type T Oil Seal, Output Shaft Seal.
OEM Type D Oil Seal
90316-72001
(replaces: 90316-A0001)
Fits 2004 to 2024
The seal listed above is not left or right specific. If you are replacing both CV axles, you will need to order 2 of these seals.
The seal listed above are sometimes Oil Seal, Wheel Bearing Inner Seal, Knuckle Seal, Knuckle Dust Shield, Knuckle Oil Seal, Seal Type D Oil.
Front Knuckle Grease Cap
43442-35060
Fits 2004 to 2024
Flange Nut Styles
If you keep your existing OEM 4th gen CV axles and rebuild, you will need to use the older style flange nut (90178-28002), castle cover (43525-35010), and cotter pin (95381-04045). Some mechanics suggest replacing the cotter pin whenever you replace the CV axle, since it is a critical safety component.
If you install new OEM 5th gen CV axles, you will need to use the newer one-time-use flange nut (90177-A0023), which is staked in place and does not use a cotter pin.
The difference between 4th gen and newer 5th gen CV axles can be identified by looking at the threaded end. The newer 5th gen CV axles will have a groove cut out.
Reboot Kit
The only difference between the reboot kits for the 4th gen and 5th gen is one of the boots for the 5th gen is different, and supposedly more robust.
Grease
90999-94187 (dark for outer boot)
90999-94250 (tan for inner boot)
The reboot kit comes clamps, and two types of grease. According to Toyota mechanics and online posts, nobody has ever got a straight answer from Toyota on which grease goes on the inside boot and which grease goes on the outside boot. According to one TSB for Camry, "Toyota CV greases are now the same color, inboard/outboard, but are still different and should not be mixed up."
Still researching this. Will edit when I find a definitive answer.
According to this post:
Inner CV boot kit came with two kinds if grease. What do? | Page 2 | Tacoma World
Tan grease = inner boot
Dark grease = outer boot
It's very important to pay attention to the amount of grease specified in the repair manual. You may need a small weigh scale measure out the correct amounts of grease for each boot.
When removing the metal cap from the wheel hub, take your time. It can take quite a while to separate from the hub, without destroying the cap or putting a hole through it. This is a critical component which keeps water from getting into the axle and flange nut. Use light taps all around the edge with a flathead screwdriver, and some rust blaster will usually do the trick. Took me 10 minutes to get each one off. I had to tap, rotate, tap, rotate, all the way around, about 10x on each cap. Also be careful not to ding the mounting surface of the hub. The screwdriver can slip sometimes.
It's very important to pay attention to the amount of grease specified in the repair manual. You may need a small weigh scale measure out the correct amounts.
Helpful Videos
Car Care Nut - Never Replace Your Leaky Axle | Fix Them Instead
https://www.youtube.com/watch?v=YH5Cf7uJV5Y
How To Replace CV Axles 03-09 Toyota 4Runner
https://www.youtube.com/watch?v=ztEh94ewK38
How to Replace Front Axle 03-09 Toyota 4Runner
https://www.youtube.com/watch?v=5HZ2xKf2r_w
Brake Notes
Cleaning Rust
Some mechanics use an abrasive grinder wheel to clean up the hub. Car Care Nut does not. He suggests using only a simple wire brush to knock the rust off. If you use a grinder wheel and get too aggressive on cleaning, you can create micro waves in the surface of the hub. This is not good, because the rotor needs to sit flat against the hub.
Silicon Based Lube
Use silicon based brake lube for rubber components, such as slide pins and piston seals. Some types of brake grease used on shims and other areas of the caliper will degrade rubber components.
Lube Application for Slide/Guide Pins
Do not use too much lube on the slide/guide pins. The pins should not push back out easily, when you press them in. Many people use too much lube on these pins.
Lube Application for Anti-Rattle Clips
Some mechanics apply brake grease between anti-rattle clips and caliper. Care Care Nut does not do this.
https://www.youtube.com/watch?v=qcGPRntO2Ws
Brakes - 5th Gen Parts
OEM Front Brake Calipers
47730-60300 (Left)
47750-60300 (Right)
OEM Front Brake Caliper Flange Bolt (2015+)
90105-A0336
OEM Front Brake Caliper Flange Bolt (2010-2014)
90105-12331
OEM Rear Brake Calipers
47750-34030 (Left)
47730-34030 (Right)
OEM Front Brake Line to Caliper Tubes
47314-35320 (Front left)
47316-35280 (Front right)
OEM Brake Hydraulic Hose Caliper Bolt Washer
47389-50020 (Front and Rear)
OEM Rotors
43512-60191 (Front)
42431-60311 (Rear)
Stainless Steel Braided Brake Hose Kit Rear Stainless Steel Braided Brake Hose Kit
Stoptech 950.44507
Akebono Brake Pads
ACT976 (Front)
ACT606A (Rear)
Akebono parts website shows both pads fit 2004 to 2024.
Akebono's website used to list ACT606 and ACT606A as compatible rear pads with 5th Gen 4Runners. Now, their website only lists ACT606A as being compatible. ACT606 appears to be discontinued as it no longer appears on the Akebono parts website. The only difference between these two pads is ACT606 had a built in wear indicator, and ACT606A does not.
Akebono pads come with shims, anti-rattle clips, and wear indicator / squeeler clips. Be sure to remove the shims and apply a light coat of brake lubricant between the shims and the backside of the pads. The lube helps absorb vibration.
For 5th gen brakes, Toyota factory only installs one wear indicator clip per caliper. For the front pads, the wear indicator clip is installed on the inside pad, on top. For the rear pads, the wear indicator clip is installed on the inside pad, on the bottom.
Akebono Parts Finder
Updated my notes to be more comprehensive. Toyota has changed a lot of part numbers over the years and older posts I found on the web are no longer accurate for some part numbers.
Brakes and Rotors
Tools
  • Small flathead screwdriver
  • Small wire brush
  • Small pry bar
  • 21mm socket (lug nuts)
  • 17mm socket (guide pins, mounting bolts)
  • Ratchet
  • Breaker bar
  • Medium Torque wrench
  • Floor jack
  • Jackstand
You can get away with 3/8" drive sockets, but 1/2" is suggested, especially if you have a lot of rust.
Optional Tools
  • Brake caliper press
  • Impact driver
  • Impact sockets
Sprays and Lubricant
  • Copper anti-seize spray
  • Ceramic based brake lube
  • Silicon based brake lube
  • Rust remover spray
  • Brake cleaner spray
Safety First
  • Latex gloves
  • Safety glasses
Will add additional notes for CV axles soon, as well as torque specs for everything.
Thank you for posting all of this great info. I wanted to get your opinion on why I am having a steering wheel wobble from 40-50mph and pull to the left, after installing the 5th gen CV Axle assembly on front left, (43430-60083).
I had a trusted mechanic install the CV axle, and new Toyota Lower Control Arms. Also new alignment bolts, cams, etc. This is an old school alignment shop so they also aligned it.
I will also add that the vehicle has fairly new Michelin LTX Defender 2s, that I have swapped sides to check that, balanced again as well. In addition, I had Toyota OEM front wheel bearings assemblies and hubs installed about 9 months ago.
The wobble and pull to the left happened after the recent install of LCAs and 5th Gen CV axle.
What would be your guess? And what would you start looking at? I have taken the vehicle back to the shop and they are sincerely wanting to get this fixed, but they recommended doing a full front to back wheel rotation and bring it back after that. I'm at the point of ordering the specific CV Axle for my 4Runner, (43430-60062) and having that installed. I am also thinking of going to a decent local dealer and pay the $129 for their alignment as well.
Thank you for your post, and thank you for any input here..
