5th Gen 3D Printing Round Up
DiscoJon
All files are uploaded in .3mf formats only. You can get separate the individual bodies as needed from this file. Source files are not available due to IP theft prevention. You can request modifications in the comments if necessary. All of these items fit based on a well tuned MK4S with MMU3.
5th Gen 4Runner Accessories by DiscoJon | Download free STL model | Printables.com
If you like my work please consider leaving a tip
Radio Knobs:
Direct replacement for the cheap OEM knobs. Available with or without knurling.
Print 2 (left and right are the same)
PET-G recommended
HVAC Knobs:
Direct replacement for cheap OEM knobs. Available with or without knurling. Fits models with dual controls as that is what my truck has.
PET-G recommended
Center Console Organizer:
Fits on Prusa MK4S bed. Print top lips separate and glue on. Available with integrated wireless charger (purchase this Amazon.com)
PLA / PET-G recommended
Tacoma Shift knob Trim:
Allows mounting of Tacoma shift knobs that have a shift boot.
PET-G / TPU recommended
OEM HVAC knob Trim ring:
Change the color of the trim ring on the OEM HVAC knobs.
PET-G recommended
Console drawers:
Small and Large available. I'd suggest printing with fuzzy skin for fronts for additional texture.
TPU recommended
Vent Inserts:
Change the color of your vent inserts. Print 4
PET-G recommended
Heritage Badge Hitch Plug:
Fits 2023 4runner, may fit others. Separate bodies for each color insert. Designed to be printed with a multi color printer as there is zero tolerance between bodies.
Heritage Keychain:
Separate bodies for each color.
PET-G recommended
Heritage License Plate Frame:
Split to fit on MK4S.
PET-G recommended
Heritage Grill Badge:
Designed to be printed with Multi-Color printer. Uses M3 heat set inserts.
PET-G recommended
Printed the lower cone for the Taco shift knob. Came out pretty good! Sent a small tip, appreciate your time into making this happen.
I like the way the Taco knob feels and it looks great! Much better than the feel of the Limited knob.
Vent inserts-
I broke the little directional clips that you use to adjust the vents vertically and horizontally for the driver and passenger side dash vents closest to the doors
Are those replaceable? Or do I need to replace the entire inserts?
For that matter, anyone feel like making them for me for a reasonable price?
Thanks in advance!
seltzernator
