5th Gen 4Runner – On Board Hot Shower (Heat Exchanger, DudaDiesel)
johnnywofee
5th Gen 4Runner – On Board Hot Shower (Heat Exchanger, DudaDiesel, $<100 with )
*****Any 5th Gen 4Runner Owners install this under the hood, Heat Exchanger+Pump < $100 ??????
After using the Coleman Hot Water on-demand for years, I was suffering from this bulky design and difficult setup during road trip and camping.
I start to look at alternatives including another standalone hot water on demand system (Coleman or Mr. Heater B.O.S.S) or on board shower with a heat exchanger.
Certainly, there are pros and cons of different kinds of hot shower system while you are on the road. I am looking for something that it can be easily setup with a non-tech guy (like me, no knowledge of the engine/mechanical stuffs at all) without major change under the hood :
1. Heat Exchanger Types : I read through many forum, some of them are self built (brass/copper rods) or purchase a complete set kit (e.g. Helton). They are all outside my technical capability or budget. Recently, people start to use some kind of plate exchanger (e.g. DudaDiesel). They are more affordable nowadays ($40-$110). They have different size, plates and connectors type. Some people said 10 plates should be good enough, meanwhile some people want 40 plates since it can produce hot water even though the engine is in idle state (e.g. 800rpm). You can also adjust the temperature of hot water by changing the air-heater temperature level inside the vehicle (basically control the coolant flow rate).
https://www.dudadiesel.com/search.php?query=b3-12a
a. By adding this kind of Heat Exchanger (e.g. connect in series with the Core Heater return Hose), is there any potential risks in terms of mechanical failure (e.g. coolant leaks, pressure level reduced, heat exchanger cause fire……..) ??
b. Any 5th gen 4runner owner install DudaDiesel plate heat exchanger ? How many plates ? Which model you used?
c. What connector types/size would be the easiest for non-tech person to carry out this project in the 5th gen 4runner? E.g. ½” Male NPT, ½” Hose Barb, 3/8” Copper Sweat…..
d. I want to have “warm water” even though engine is in idle running (e.g. 800rpm) and water temperature “can be increased” by air-heater level inside the vehicle. Should I go for 40 plates instead of 10 plates? (Some people said, more plates may not help too much on temperature, surface area is the key instead)
e. After you install this type of plate heat exchanger, will it be cracked/damaged during winter of freezing weather, some water was left inside the exchanger, right?? What are you going to do in winter time?
2. Connection method :
f. I look under the hood, there are 2 pipes (coolant flows through them) of core heater hose going through the firewall into the vehicle. Anybody knows :
Upper Pipe (Coolant returns from the heater) ??
Lower Pipe (Coolant flows into the heater) ??
Certainly, it can be verified by touch them to see which one is hotter (flow into the core heater). But this is not scientific, could be wrong !
g. I intend to connect the heat exchanger in series with the coolant return path (i.e. after coolant going out from the core heater unit). Then, I just need to disconnect one hose to minimise the change. There is no impact on existing core heater for its heating performance. I can also control the water temperature with the core heater knob (coolant flow rate) inside the vehicle as well. Anyone has such similar configuration setup in the 5th gen?
h. :surfer::surfer::surfer:What is the dimension of the core heater hose that I should buy?
3. Tool and Skill : I do not have any tool to disconnect the core heater hose and reconnect it to the heat exchanger, looks like there is a clamp to release and then reconnect, is there any special tool/skill for this installation? This is another reason why I want to choose the simple connector types of the heat exchanger to match the hose dimension. I want Plug and Play method if possible.
4. After installation: I need to refill coolant (there may have some lost by redirect it to the heat exchanger)? How can I verify the existing core heater (hot and cold air blow out from it) still functioning as before? For those professional mechanics, do they have any tool to check the coolant pressure/level, heater performance??
A lot of folks have looked at this, no comments yet, I've not seen anyone with a 5th gen do this. Personally the thought of a warm or hot shower sounds good but this seems like something that has too much potential to compromise the durability of the truck, but then again it's my completely uninformed opinion.
:tea:
5th Gen 4runner On Board Hot Shower (<$100)
Looks like 5th Gen 4runner never did this modification to the vehicle to divert the coolant to a heat exchanger of a hot shower system. Does it mean that :
1. There is a potential risk to MODIFY (not add) the engine system and it could void the manufacturer warranty ??.
2. If the installation is not properly secured, there would have coolant leaks from the heat exchanger or the hoses connecting them together. It may result in engine overheat, it would be extremely dangerous while driving on highway??
3. To keep the pump and heat exchanger permanently inside the vehicle, but only use them few times a year, WOULD NOT be justified to have these potential risks. You also need to take care them during winter time (water is still inside).
I do a search, this modification was done in other vehicles including Tacoma, Tundra, Jeep,.... but they may be older vehicle (at least several years old). The 5th gen 4runner is pretty new (max 6 years old), owners do not want to do such big modification ???
On board shower - Expedition Portal
I enclosed a picture of the configuration (from another forum) to trigger your thoughts about this.
PLS SHARE YOUR VIEWS of such on board hot water system in the 5th Gen 4Runner.
4runner Hot Shower on board (<$100)
:washing::washing::washing:It is found that there is a 4th Gen 4Runner owner built on board hot water system in his truck. Looks like he is a very professional person and did lots of advance improvement in his vehicle.
Is there any 5th Gen 4Runner install similar on board hot shower (using heat exchanger) ? The cost is really competitive with only less than $100 for this project. Certainly, I would like your advice of any concerns with such modification (i.e. to redirect the coolant flow to the heat exchanger).
Here is a picture of the 4th Gen 4Runner and he is on Youtube to show it as well, very nice built project:
https://www.youtube.com/watch?v=hjDU9qc7Rdc
I'd just get an L5 Eccotemp and call it day...I agree with [MENTION=91899]Jhalko[/MENTION]...why take a chance of something else you "cut in" the truck system for something you're going to use a few times a year.
cool factor..a 10....practical?...I'm not sold
5th Gen 4Runner Hot Shower On Board (Heat Exchanger)
:rolleyes:Finally found a 5th Gen 4Runner installed this kind of Hot Water Shower On Board by using heat exchanger method.
It would be nice if any other 5th Gen owners can give more comments about such configuration setup.
Certainly, if you or know anyone who has done it before, it would be nice to share their practical experience.
http://www.toyota-4runner.org/5th-gen-t4rs/102292-them-me-mods-31.html
My turn for questions
I'm diving into this now and am running into the same questions.
Did you ever get the answers to your questions? Particularly, the one about the coolant pipe flow. Was the top one the return like you thought?
Also, where did you end up mounting your heat exchanger, pump and hose connections? Best I've come up with is on a hidden bumper bracket in front of the radiator as my engine compartment doesn't seem to have enough room after my dual battery install.
Thanks in advance for anything you can pass on.
REE
