The power assist is electronically controlled, not vacuum like other makes.I know about all those, but what about just braking in general?
See but you are ignoring part of my post. If it fails one time, it isn't going to work just fine after that with no signs of why it didn't work that one single time. Obviously it can fail internally, but if it fails it fails. And obviously if a pad fell out that would be pretty clear.
Hydraulic systems can do strange things, and not leave any external evidence.
For the record I'm not saying that I don't believe anyone who said their brakes failed. I'm just saying I don't see how it is possible with zero evidence.
There may not be any external evidence. Once the system is removed and torn down, there may be signs of twisted seals, or burrs in the hydraulic cylinders that caused the issue.
Just for the record, use Weathertech Mats. The standard mats are pulled and stored under the rear cargo liner. Routinely check my tire pressure, know how to listen to an engine and when motivated can pretty much tear down and rebuild the vehicle if I wanted.
That said, it's not a small thing to the person who has the brakes completely fail when driving and kinda makes the probability discussion a moot point.
This my third T4R and first one where I've had a serious mechanical failure. Let's hope Toyota does the right thing and change out the Master Cylinder unit.
Totally disconcerting, especially when the dealer isn't willing to believe you. Lots of techs these days have no diagnostic skills - if it's not on the computer, they have no clue what to do next. On this one, I would want the master cylinder replaced at a minimum.
actually, ive heard that based on how warranty work is billed, dealerships usually lose money on warranty repairs.
There's no way a dealer loses money on warranty work. Make less money, maybe, if Toyota doesn't reimburse the entire book rate for a repair, than a customer repair, but they don't lose money.
