5th gen rear bumper repair
T4RZAN
Hey guys,
Curious if anyone would know an estimate to get this fixed? Not really worried about the paint as much as I am the dents. Or anyone know a home remedy? Thanks
Hey guys,
If you can reach behind, I have seen people pour boiling water on the dent to heat it up, then reach in with a block or something and push it out. Might have to hold it till it cools down. Running cool water over it after pushing might work, but don't know if that would cause the paint to check or not.
You can either push it out from the back side but the paint will most likely be spider webbed and cracked. No real repair for plastic bumper you would have to replace it if you want it to look factory again.
Sent from my SM-G935V using Tapatalk
You're going to need to get it assessed. There may be broken brackets and such. With how damaged it is. You're probably not fixing it by pulling it out.
Hmm...
I recommend looking into the aftermarket rear bumpers from folks like CBI, Shrockworks, Etc. IF you had this issue once...I'm thinkin' it may happen again! Better to have and not need than to need and not have.
Happy Trails!:cowboy:
Be careful where you go to get it fixed. My truck is still (minus 7 days or so) in the shop now going on 6 weeks for a liftgate repaint and repaint. Been a nightmare.
Any body shop should be able to give you a repair estimate. Sometimes it costs a few bucks that get subtracted for the cost it they get the work.
Order a new plastic bumper. Probably not more than 300 bucks. Then take it to a place to have it painted. Then install yourself. Install will take all of 30 minutes.
I've pushed out worse deformations than that using a heat gun. In your case you may need to remove the bumper cover to gain access to the backside. What have you got to lose? If it doesn't work the repair facility will replace it either way.
I've got similar damage due being rear-ended. Only got about $1k for it and will be putting it towards a rear bumper
X2 on using a heat gun. had a HUGE dent in the bumper cover of my TSX, used a pot of HOT not boiling water, poured it over, then had my gf hit it with her blow dryer while i just used my fists to push it back from underneath the car. Im new here and don't know to embed youtube videos, but you can search something along the lines of "Bumper cover repair boiling water" etc etc etc and get an idea of what lies ahead.
Hey guys,
Hi T4RZAN,
I did the very same thing backing up into a snow-bank at the supermarket; I didn't even discover it until the next day because it made no sound when it happened. But I remembered when I created a dent on the right side when I rubbed it against a cable wire loop on a wall trying to park too close about three weeks after buying the LE; I was devastated!
But I found a dent wizard shop that could remove the dent on the spot and they came to my house to do it! The technique they used was to rub it out from the inside of the fender and it came out perfectly! So when I dented the bumper, I just used their technique. I climbed underneath the rear of the truck and using a 1/2" x 3' ratchet extension I carefully rubbed it out from the inside of the bumper (don't tap or bang it or you'll leave marks), and you can't even see it!
Why not give that a shot, what do you have to lose? Just work very slowly concentrating on outer parts first to help stretch the material outward and then after that, start working on the center. Just use a lot of light so you can know when to use more or less pressure, and take looks at the outer part of the bumper so you don't go too far out; just take your time and that will work! I think I spent about three hours to complete it but now you cannot see it!'Best to you'
rig
Just had mine replaced (twice), the estimate for an aftermarket bumper was $287 plus 2.6hrs for paint/prep.
They had to replace the a/m part with OEM due to fit issues, the OEM shows a price of $337 plus 2.6hrs for paint/prep.
That was for a Trail bumper. The valance was not included in that price.
It looks somewhat torn in the pictures where it was pressed against the edge of the frame. Could be just me looking at it funny, but it doesn't hurt to try a heat gun I suppose, worst case scenario you're back to assessing damage and replacement.
