Brodozr909
I just picked up a set. Thank you for the discount code.
[MENTION=133641]Salex[/MENTION]
I have a suggestion, if you removed part of the tray rail it would allow the tray to be moved slightly back which may not seem like much but it is just enough for me to be able to reach credit cards, door bags, etc. stored in the lower front pocket. Some pics of my modification.
I agree. I have a usb/3-prong plug adapter plugged in, it's a little too tall, luckily it has a bending neck. To use it I have to remove the tray. Sliding it back might allow just enough room to not have to remove it.
I also agree. I would even like the tray more if it was smaller, one bin instead of two. I could use it for my sunglasses and move the tray back and forth to access the bottom area.
And thanks Salex for "Made in the USA."
Does anyone mind sharing the dimensions of their center console tray? Width, length of entire tray, and how wide the 'lip' that holds the tray up is?
Much appreciated.
Edit: I have no intent of copying the product; I just want to know whether I would be able to customize for my own uses before I made the purchase (I want to compartmentalize more, add coin holder, sunglass spot, etc.). If the original Salex designer has any opposition to this, please say so and I will delete my post.
Much appreciated.
