I think some of it has to do with using Tapatalk. I've gone and looked at mine and went whoops! When you upload straight from a phone, you have a bit less control. But then reversed, when you use Tapatalk to view the threads, everything fits until you click on it to enlarge.
Got the new trail premium yesterday, keeping it stock for now but I'm sure there will be a few tweaks in the near future.
That's a great idea. I've been looking at doing it myself. Did you go to California location (Nm, just realized you're in SoCal)? If you don't mind sharing, what was the price range? No prices on their website.![]()
XPEL Ultimate clear bra installed on the whole front end! Bumper, headlights, fog lights, hood scoop, fenders, fender flairs & side mirrors. It looks amazing great work by clear-pro.com!
He was even nice enough to do the part behind the door handles for free!
Thank you -
I've had my 4R 1.5 weeks and have already found a chip. Doh!Given the amount of labor and the fact that he's mobile the pricing wasn't bad. All up it was $1700. I wanted to get this done before our big road trip anyways to prevent even more rock chips (i found a few already and wishing I did this sooner!)
Thank you for sharing! Did you have to drop the headliner for the wire install?Finally went and installed my antenna mount and fished the wire through the body panels to get to the center console. Still haven't tested it out because I need to run wires to the battery and hope that my old ICOM radio still works haha. I've been asked before, so I'll post that this is for a HAM set up.
Black Diamond K400CNMO Mount with Comet SBB1 flexible antenna for every day driving. Then I have my old long antenna for when I go to the trails.
**Working on getting my tech license, so another reason why it's not fully plugged in.
Awesome. Thank you! I did the install with my Fj but no headliner routing was required. This looks a little more complex. Looks fun. [emoji2]I pulled down the headliner at the back at the door seal, just enough to see where the hatch wires were and grabbed the connector with my fingers. I did not remove it though. Once I had it fished through that couple of inches, I ran some bailing wire(coat hanger works too) over the headline(closer to the side trim) down to the jack compartment, then did a sawing back and forth deal to work the wire up higher through the headliner. Just slowly used the wire to find good holes and pulled the antenna through. It goes to the side, down the (D?) pillar, through the Jack storage, into my now new rear tire storage(Antmans brute force method), pulled the back seat recliner handle cover out for the next part, then down to the bottom floor trim at the door(pulls off easily). I then popped the drive seat bracket covers off(rear brackets) and fished it under the carpet from the door trim. It's currently poked through the right rear driver seat bracket hole. Once I run the wire to the batter and tear my center console apart, I'll route it the last few inches.
Will do, thank you.It was actually a lot easier than I thought it would be. Just go slow and use the coat hanger. I was very happy that I didn't have to pull the headliner! Haha
