60,000 mile service
molocono
I have an '04 SR5 V6 with 60,000 miles on it. What are some of the things I should change/check? I changed spark plugs at 30K and diff fluids at 50k. Thanks!
spark plugs again, check air filter, clean MAF, lube the ujoints and slip joint look it up in your service interval pamplet.
Or take it to the stealership and pay $500+! At least most of them give you a free rental for 1-2 days. I'm gonna dread when my truck gets to the 60k interval. I only have 20,321 miles on my baby now.
Found here.
Replace engine oil and oil filter 1
Rotate tires
Lubricate propeller shaft (4WD)
Replace spark plugs 2
Re-torque propeller shaft bolt
Replace engine air filter
Replace cabin air filter (if equipped)
Inspect the following:
Automatic transmission fluid
Ball joints and dust covers
Brake lines and hoses
Brake linings/drums and brake pads/discs 3
Charcoal canister (2UZ-FE) 4
Drive belts 5
Drive shaft boots (4WD)
Engine coolant
Engine valve clearance
Exhaust pipes and mountings
Front differential oil (4WD)
Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
Fuel tank cap gasket
Radiator core and condenser
Rear differential oil
Steering gear box
Steering linkage and boots
Transfer case oil (4WD)
Additional Maintenance Items for Special Operating Conditions:
Driving While Towing
Replace front differential oil (4WD)
Replace rear differential oil, including limited-slip
Replace transfer case oil (4WD)
Replace transmission fluid or oil
Tighten nuts and bolts on chassis
Driving in Desert or On Dirt Roads
Applicable Footnotes:
1) Reset the oil replacement reminder (
