8.2 Axle
Fern
I'm thinking about upgrading to an 8.2 rear axle out of a 2010+ 4runner. Is the gear ratio the same? Are the both 3.73?
You can also swap in GX470 and FJCruiser axles that have the larger rear diff. I believe the only gear ratio that differs is the manual transmission FJC.
The VIN off the donor vehicle will tell you the gear ratio if you have it.
