The vehicle:
1987 Toyota 4Runner 22re auto trans
Here is the problem:
My brother owned it and just recently turned it over to me. He said it just sputtered and died while driving.
Parts I have replaced:
Fuel Pump (only works when jumper wire is used in diag area fp & +B)
Fuel Filter
Plugs & Wires (spark checked)
Cap & Rotor (timing is on)
Throttle Position Sensor (TPS) (not set yet but i was told it should still run)
After working on it steady for the last few days (because it is mine now) I have found the the fuel pump dosn't kick on at all even when cranking over. So i did the jumper thing and the fuel pump now runs but only with the jumper hooked up but still no start. So I pulled out the cold start valve and it was very dirty so i cleaned it up with carb cleaner and reinstalled it something tells me it isn't opening as it should. Is there any other tricks I can use? I am pretty much stumped on this thing. So any help would be greatly appreciated.
Codes Thrown:
11- TPS amongst other things (cleared)
2- AFM open or short circuit
8- AFM or manifold open or short circuit (cleared)
Sorry for such a long post I wanted to eliminate as many questions as possible.
Fuel Filter
Codes Thrown:
