my 4 runner has the following transmission symptoms:
shifts into 1,2,3,4 fast! no matter my throttle posistion
will not downshift automatically
shifts manually perfectly
all shifts firm and healthy
how do i test the tps? fsm says test ecu ports, but they are under the radio, cant get probes in there muchless see what im doing.
i pulled the rubber boot off the tps and tested voltage between top two wires. i have a .1v closed and about 1 volt wide open.
checked with ohmeter the top two connectors with wire harness off the sensor.
open leads with throttle shut
1.4k ohms wide open.
