Rolltide10
Thoughts on running these with stock shocks in the rear? Want to level the front out and it says gives about 1 and 1/2 inch of lift. Any idea what size tire i could run without trimming?
A two inch lift in the front and nothing in the rear means it is going to sit really high in the front, look weird in other words. The 1.5" would sit high, much less 2".I you want to pay the shipping you can have my old Revtec spacers - they would sit on top of your stock springs and give ya 2in of front lift. I think you could use the stock shocks. Those darn things are heavy as all get out so my be kind of expensive to ship? I replaced em with the OME stuff a few weeks ago and have zero use for em now.
Crap pix I know but you can see one sitting on the ground - 2 in black ring sits below the top plate and above the spring.
The pix is showing the comparo between the Revtec top out spacer and the OME top out spacer - the black ring in my hand is a stock piece that holds the spring.
Just measured the Revtec spacer and it was 1 1/4 - wonder why they call it a 2 in lift? The silver top plate spacer is not 3/4 in? Yours if you want em.
