89' "Sleepy" build/experiment
89' "Sleepy" build-1uzfe OBDII experiment
well finally going to sit down and make the build tread
It named "Sleepy" cause all of the hours of sleep I have given to this build.
So pick up this 1989 4runner fully optioned all power just no altimeter, not bad milage at 184k. It had all the records and docs and owned by a former Toyota dealer mechanic. He was up front about the suspension needing work and some rust spots, but said everything was sound.
Here is where it gets interesting, deal struck. Thought I was walking a way happy. Go to DMV and hit with 500 in back fees, Then the smog that was suppose to be done was not. Even worse when I took it to smog myself, it failed. Come to find out the head gasket was in need of replacement, even though the records shown it was done recently, had me wondering if PO was a salesman and I been had.
image.jpg1_zpsfrqztwto.jpg~original
image.jpg1_zpsisyym3hd.jpg~original
As it turns out, the head gaskets on the 3.0 V6 is a pain to redo, every shop and even a buddy of mines just said it was cheaper to get a rebuild and swap it.
but as luck would have it after weighing my options and looking at other's builds, I figured a swap is going to be a swap and it would be cheaper cause this came along
image.jpg1_zpszcgall9d.jpg~original
Tear down of 3.0 V6.. go bye bye.
image.jpg1_zpsngdxebu1.jpg~original
The Great RMA of yotatech Fame helping me with the tear down
image.jpg1_zps41xtmtuk.jpg~original
Ended with this
image.jpg1_zps9ndzgexd.jpg~original
while the engine bay was open it was a good time to upgrade the brakes. New master cylinder Bigger bore dual diaphragm style
image.jpg2_zps984e7hjx.jpg~original
Made space in the engine bay by converting the parking brake
image.jpg6_zpsriuwcm6f.jpg~original
Opened up the back of firewall and transmission tunnel by gently massaging it with a BFH
image.jpg7_zpspkb1pne1.jpg~original
Freshened up the suspension with OME and all new joints and rods
image.jpg8_zpsfrwj5lbv.jpg~original
body lift 1" for clearance and made the lift pucks
0ccd3582-cb65-49f5-9fb7-5f5a88158c1e_zpsyqzgsaiy.jpg~original
Installed with upgraded Grade 12.9 Stainless steel hardware
9311a197-c4c0-4056-8e9a-85f1860eb09a_zpswj0oo10b.jpg~original
built hybrid motor mounts using the factory base to keep isolators and box beams to plate for semi solid style. Made it to access bolts for easy removal.
image.jpg5_zpstih3syf0.jpg~original
So to keep everything California Legal and Certified had to go find the charcoal canister. Dealership wanted 1K+. This little canister had to match the engine and ecu being the donor motor was a 1995 with OBDII. what a pain
3c908ec5-8f10-40da-8f03-55f48d35cbdf_zps3beettxv.jpg~original
also to keep it smog legal it needed the complete oem exhaust manifold and oem catalytic convertors from an OBDII. So to fit the exhaust manifolds, the 2uz 1995 tundra log style was used, mated them to the Lexus 1uz catalytic convertors.
image.jpg8_zps146plgvp.jpg~original
had to add the EBR port to keep it all legal
image.jpg9_zpsdcbtmqqo.jpg~original
image.jpg10_zpsa1jab68g.jpg~original
Bam all buttoned up and stock legal like, also the routing was turned in a little to clear the transmission and tunnel.
image.jpg7_zpstcy96dps.jpg~original
image.jpg26_zpsb6xiw6u9.jpg~original
swapped out the LS400 oil filter mount to a new SC400 version to gain clearance
image.jpg12_zpst3d1a6jo.jpg~original
Plugged to OEM 4runner battery tray to make space for the 1UZ air box and map sensor
image.jpg17_zpsuda5begc.jpg~original
So to keep the A/C and power steering the pulleys were swapped on 1UZ units and 4runner. that way i could use most of the original 4runner A/C hoses
image.jpg8_zpszo7kqm5d.jpg~original
but to do that custom brackets for bot the A/C and power steering had to be made. cut apart a 4runner A/C bracket and welded mounts to the 1UZ motor.
image.jpg10_zps6lkwmq3y.jpg~original
image.jpg11_zpshasawwhy.jpg~original
All buttoned up and tested the belt.
image.jpg13_zpsesh1czvw.jpg~original
So this was the gap or clearance use. not exactly what a shop would use but hell it was 1" and it gave some play and flex for moving the motor.
image.jpg16_zpssbq1ssb0.jpg~original
image.jpg15_zpspzv3lw7d.jpg~original
motor is in, kept the cruise control in hopes to get it working later.
DSC03622_zpsbde7d81f.jpg~original
So Transmission time, to pass California smog laws the swap has to use oem equipment. The 1UZ USDM never came in a 5sp so the automatic transmission had to be used. A SC400 transmission was selected because of the very so slight gear ratio profile. So to convert the SC400 auto transmission to 4 wheel drive there was an oem option or the 1k inchworm pre runner adaptor option. Since the cost was a factor and there was no guarantee to pass California smog, the oem or low buck option was used. Found a T100 3.4 v6 passenger side drop transfer case and tail housing, mated it to the SC400 transmission. The A340 transmission was used in just about everything Toyota made that time period but there was still some provisions that needed to be made
Tapped the SC400 transmission for the T100 tail housing
image.jpg15_zpsqeaywqic.jpg~original
modified the output shaft for magnetic speed sensor and to fit the T100 transfer case
image.jpg18_zpshripvdpi.jpg~original
Freshened up the transmission and cleaned everything up after modifying the output shaft
image.jpg19_zpswgetpppv.jpg~original
Got excited and did an OEM transmission pan swap. The T100 3.4 transmission pan had more volume than the SC400 one so swapped them, also notice its high clearance on the passenger side to clear the drive shaft. Only time will tell if it works. kept the SC400 pan incase.
image.jpg23_zpsyq3rkg3y.jpg~original
SC400 transmission pan
image.jpg20_zpsk6p4f3cl.jpg~original
SC400 Transmission with T100 3.4L oil pan
image.jpg14_zpskz94ytm6.jpg~original
modified the T100 Tail housing for the oem 1UZ magnetic speed sensor
image.jpg16_zps7xski2sv.jpg~original
Freshened up everything and mounted tail housing
image.jpg22_zpsswk5qchc.jpg~original
Freshened up the transfer case and mounted the speed sensor. was afraid of leaks so extra silicone. also new seals. added a bracket for good measure
image.jpg21_zpsckaa0n4c.jpg~original
alright the transmission all freshened up and put together. Pretty much all OEM parts and all plugs checked.
image.jpg24_zpswfvjozlj.jpg~original
Freshened up the torque convertor and don't know why there was so much royal purple used.
image.jpg2_zpsca7bvvi6.jpg~original
Ready to go in
image.jpg3_zps617oejcm.jpg~original
All in and clearances checked
image.jpg8_zpsfjjednfw.jpg~original
image.jpg7_zpsjk3wk268.jpg~original
Bonus using the transmission pan from the T100 3.4 v6 was that transmission pan had provision for the front drive shaft being passenger drop transfer case
image.jpg4_zpsrnlmpfuc.jpg~original
moved to some wiring to make sure the motor fires and runs before tackling other things like drive shafts and shift linkages and building a transfer case mount.
Wiring is ooh so fun and ....
14522eb3-a3b1-4f4d-821e-7b642c090841_zpsuaertfbz.jpg~original
out with the 4runner cluster
image.jpg10_zpsfl3z61vo.jpg~original
in with a Modified lexus SC400 cluster for all the modern convinces
image.jpg12_zpsz0pdccyf.jpg~original
also the Lexus cluster needed way more space to fit and space for all the extra wiring.
image.jpg11_zpszbqvpqte.jpg~original
So had to hunt down some parts, the 1UZ was mostly complete but some parts were parted prior to getting it. Needed to find the correct Mass airflow sensor, correct set of ignitors, air box and coil for the motor. learning experience make sure all the smog legal stuff is there.....
notice the cut wires for the MAF. on a good note the fuel lines routed and should be easy hooked up with the rite fittings.
image.jpg1_zpsw1qvplz3.jpg~original
So this is pretty much what it takes to get the SC400 cluster to work. All wires from ECU label and pulled to the cluster, addition wires made for the harness to get the trip meter working on the harness side and confirmed with the wire diagrams
image_zpsj1vdejnc.jpg~original
All wires labeled on the cluster side and confirmed
image_zpsppzgsjp6.jpg~original
the SC400 cluster with custom bracket to fit in the factory position
image_zps6sp2ajhl.jpg~original
WOW! awesome work and patience!
Even when the day is done and I fell asleep, I would be dreaming - or having nightmares about those wires! :)
Happy New Year and best wishes with your build!
Looks very good man! I'm sure that engine will be fun.. only concern I would have is it being a bit much for the rest of the drivetrain.
Getting trip meter and illumination to work. so swapped out original 4runner one with newer SC400 unit
image_zps21qas8a8.jpg~original
wired in the OBD2 port need to make it smog legal.
image_zpskeemnfhe.jpg~original
with the ecu size difference between the 4runner and 1uz there was no other place to put it beside below the passenger seat. so that means extending all wires, the biggest pain was extending the wires with the correct colors so it matched a factory lexus LS400 wiring diagram. if you look close, used all oem wires color matched that was cut from a donor harness from local yard
image_zps8rx2ue0x.jpg~original
