89' "Sleepy" build/experiment
So most of the wires pulled to the Cluster and loose fitted
image_zpsj8whvzgh.jpg~original
Most of the wires connected to the ECU, insuring the OBDII and smog ports working, then most of the additional wires pulled to the main engine bay
image_zpshhjloyie.jpg~original
Pulled all the wires from the ECU to the Engine bay. Time to make a new hybrid harness for the 1UZ.
image_zpszg74ihlm.jpg~original
So the 1UZ has way too many relays, so out with the original 1st gen fuse relay box and it was replaced with a 2nd gen 4runner fuse relay box. The 2nd gen gave enough relays and fuses to run the 1UZ and the bonus was it fit in to some existing holes with out major modifications.
image_zps9i1xiylz.jpg~original
The 2 gen fuze box had a bonus and had 2 relays, one to run the electric fan conversion which gave just a little more space for the motor to come forward and clear the fire wall, the second relay will now become a spare for a LED light bar or something at a future date.
image_zpsqkdlzy5e.jpg~original
Decided to upgrade the wires while inside the fuse box and started a big 3 up grade
image_zpszd8h8zlj.jpg~original
Most everything button up inside the fuse box
image_zps5yu9rimo.jpg~original
So dimmer all wired up and the trip meter set
image_zps0hetgwvo.jpg~original
Engine bay wires being button up and fuse box placed for some fitment. need to insure the OEM air box can fit for smog reasons
image_zpstxeu2vdv.jpg~original
one other quick mounting check and wiring check
image_zpsbfcezqeb.jpg~original
Took a break from wiring and figured it was time to build a transfer case mount.
took measurements several times then took them again
made a template out of card board. wanted fuller coverage so it was a mount and skid with a slight angle.
image_zpsbp5rpqcd.jpg~original
mocked up next to the next to the 3/8" steel. if it is good enough for bud built, its good enough for me
image_zpszm1jqxgl.jpg~original
Took it to the local steel shop and had them do just do the bend on their machine.
Cut out holes for the transfer case mount, then measure it versus the OEM mount to be able to use the factory mounting points but hit the correct spot for the 1UZFE set up. Notice the mounting point sits several inch further toward the rear.
image_zpsygoltutq.jpg~original
Gonna have a LOT of questions for ya when I start mine!!!
First question now is, was the massaging of the firewall unnecessary in the end, since you are going to run an electric fan? Or, did you still need the extra bit of room to make it fit?
Just drove close to 2000 miles round trip in 3 days to get these things:
Yep! That's not one, but TWO of them there! One's going in my '85 supra, the other will eventually go into the '87 xtra cab, but I'll be doing the supra first.
guess the transfer case mount was a win
image_zpsioycwztr.jpg~original
hard to see it but there is a slight angle and the coverage was more than expected, plus OEM mounting and OEM transferase isolator.
image_zpswceys9y9.jpg~original
Shortened the rear drive shaft, the shop even put in extra slip incase of a 3" lift
image_zpswqy17avz.jpg~original
Then extended the front drive shaft to keep 4wd and everything working.
image_zpsjxflwg1z.jpg~original
now for top side fun. had to make and adjustment for the auto shifter and new 4wd shifter. The one used for the swap was a T100 3.4 v6 tail housing and transfer case to keep the auto and everything smog legal.
drilled out and trimmed and moved back towards the rear due to longer 1UZFE set up
image_zpsi2e0tiej.jpg~original
Cut out new metal and conjured to fit OEM
image_zpstkbrkeqk.jpg~original
so the shifter didn't quite fit so needed to make and adjustment to keep it stock looking. so measured twice and cut it to extend
image_zpspunymdy1.jpg~original
image_zpsjudhneob.jpg~original
welding in the extension piece to the piece that was cut off and loosely assembled to check it is looked OEM... pretty close. so now "Sleepy" build is turning into a sleeper truck with a V8
image_zpsaxdzhlxr.jpg~original
Any plans for a skid plate for the back of the tcase? Look like its hanging quite a but lower than the plate.
once it gets California bar'd and smog legal, just the process in this state to make it a DD
inchworm pre runner adaptor and 4.7 gears and a tummy tuck, is on the list
So played around with the radiator and seemed like OEM fit the best.
image_zpsezu4rtfu.jpg~original
figured the OEM V6 radiator didn't have the cooling capacity so, had it re-cored to 5 core and added a elbow at the top to match routing lines easier to keep A/C
image_zpsb6ahkcqv.jpg~original
Mocked up slim line 16" low profile puller fan and OEM radiator shroud. Massaged the shroud a bit for clearances
image_zpsxchnyr9z.jpg~original
Dropped in and hooked up new hoses. Looks pretty OEM to me
image_zpsjntusucw.jpg~original
Pretty OEM looking for the side and the electric fan fit too
image_zpsedh56yli.jpg~original
Sorry late was late night post
The raidator shop called it a 5 core, but basically the shop expanded the factory tanks and put a baffle splitting both tanks. Need to do that to keep the routing since both elbow were placed at top. Then there was a trans cooler in the raidator. So essential there is like 5 mini tanks linked by 4 rows of fins. Adjusting the OEM raidator was the best option with out cutting or moving radiator to front, still trying to keep A/C components.
Also on the return side the electric fan sensor bung was tapped in.
The 1uzfe OEM clutch fan turned on at 205 and off at 185, closest after market was on at 195, off 185. Probably wouldn't hurt since the engine bay is tight and the extra air movement would keep it close to OEM temps. Time will tell.
seriously speechless over this swap...
I'm over here complaining about installing a little ol' field monitor unit.
can't wait to see this thing burn out
Back to wiring....Pretty much all the rest of the wires from motor that need to go to the ECU. The 1UZFE has trac control.....
DSC03647_zpsh9fbfjnf.jpg~original
Ran everything through the Original firewall hole from the old 3.Slow. Again Looks pretty OEM
DSC03654_zpsdp8dj0a4.jpg~original
Brackets made for Mounting 1UZFE ECU
DSC03652_zpsgjzy6v9w.jpg~original
Mocked up and need to extend the wires to the right spot now
DSC03653_zpsg7akbuox.jpg~original
pretty much decided where to hard mount the ECU
DSC03644_zpsb3mgpj25.jpg~original
Needed to Clearance some space for the new SC400 gauge cluster
DSC03626_zpsasbj8c6l.jpg~original
SC400 Cluster modified with custom bracket and OEM 1st gen 4runner plastic screen from a donor cluster.
DSC03627_zpspbfohsnu.jpg~original
Test fitting the New hybrid SC400/4runner Cluster. going to make it looks like a stock "sleeper" swap
DSC03629_zpstu0gtvjk.jpg~original
So back to getting a little closer, making sure the signal is there from ECU and the cluster works.
The Center console and 4wd shift looks pretty stock, Hard to tell to the un-trained that its been modified.
image_zpsphgaua5v.jpg~original
Also seems like everything is connecting and lighting up like it should. The cluster is hidden nicely when off but kind of gives away that something has been modified when on. Still pretty OEM to those un-initiated to 1st gen 4runners.
image_zpstuaolewf.jpg~original
Laredotx
