Found a station with 90 Octane 100% Gas no Ethanol Fuel. So I thought I'd run the tank down near empty and fill up to see if I could get better MPG.
First I filled up and reset the on-board MPG and trip odometer. Drove 241 miles mixed highway/city. I live in New Mexico so that would include 75mph driving (legal here).
After 241 miles I went back to the same pump for a fill up. At that time the on-board mpg was 24.1 A hand calculation came to 22.11 mpg.
When I use regular 85 Octane 10% Ethanol hand calculated 20.1 MPG.
What I wanted to find out is if it was "worth" buying the 90 Octane no Ethanol Fuel.
Regular Unleaded 85 Octane is $3.49 a gallon. 90 Octane no Ethanol is $3.91 a gallon. A 42 cents a gallon difference for this test, comes to a 12% difference in price.
High octane costs 12% more, resulted in 10% better mpg.
Bottom line in dollars is the high octane 100% gas costs 7 cents more per gallon. The 4Runner seems to perform better with the high octane, faster/smoother acceleration etc. using seat of the pants measure.
Don't think I'll continue using the high octane no ethanol simply because it's hard to get, I'd have to make a special trip to get it. I have a second tank of the high octane in the truck now and I'll do the calculations again after going over 300 miles to run the tank down. Then I'll fill up with cheaper easier to get mid grade with ethanol and redo the calculations.
Edit: Forgot to mention my vehicle specs. 2006 V6 SR5 4wd
