92 4runner cut off?
jonlosha
Hey guys my names jon and I just bought my first car that's one hundred percent mine and paid off, a 1992 4runner sr5 v6 3.0 4wd 5 speed and I have a few questions about its body damage and some options.
Let me start off with all known problems, when you turn real deep it grinds and creeks, my friend who is a service tech for toyota said this is typical of all toyota trucks but isn't sure exactly what it is, mechanically everything else including the head gasket which I hear are prone to go out on these is in good condition.
Now about the body, the guy I bought it from slid it into a ditch and the passenger side front in is slightly bent and well the rear end is rough as the picture shows but for $900 I think it was a good deal.
Now here's what I'm thinking about, it would be real hard to fix that body enough for glass to be put in and stop the water leaks, I have seen people cut back ends off of 4runners to kind of give it a truck bed but how would you seal up the cab if you did that, any suggestions about how to do this if I do it? I have full access to a body shop so I have the tools.
lexan or plexy glass but you will have to weld in load bearing points to make up for the body sections you would cut off.
All in all i think its a bad idea, just find a used 4 runner with a good body and bad engine or something along that line and swap your stuff over, you can get one for about 500$ with decent body. that is what im doing right now.
Lets see I'm trying to post pictures but I'm using a mobile version and I'm new to it
Sent from my DROIDX using Tapatalk
... Let me start off with all known problems, when you turn real deep it grinds and creeks, my friend who is a service tech for toyota said this is typical of all toyota trucks but isn't sure exactly what it is, ...
Could be the plastic caps for the steering stops are gone so you have metal to metal contact at full lock.
Or you could have a bad CV joint(s).
