94 T4R noises please help diagnose
HawaiiYotaNoob
I just bought a Toyota 4 runner v6 3.0 engine 4x4 5 speed and it makes noises. First it clicks like when I gas it it clicks and as rpm go up it clicks louder and faster but no clicking when I not putting gas. Then it whines kinda loud in reverse, I believe it's normal but is it? And third it creaks when I turn left at high radius or reverse out turning left...please help. I know there are many great mechanics with input to be heard. It will be greatly appreciated, thanks.
Sent from my DROIDX using Tapatalk
1. Sounds like you need to adjust your valves. Good luck. But could be anything. Its hard to figure out a sound when you dont actually hear it.
2. Normal. But a fluid change wont hurt anything.
3. The factory plastic bump stop covers wear out easily, and create that noise. You can put some grease on them or by replacements that are better than OEM on fleabay.
Edit: Found em for ya
http://cgi.ebay.com/ebaymotors/86-9...rsQ5fCarQ5fTruckQ5fPartsQ5fAccessoriesQQvilZ1
Ok so what's the deal with the valves? I can record the engine sound for you and rev it so you can listen..this truck also seems to have no power...
