'94 V6 crank-no-start shortly after rebuild, need a little advice on ECT
identity
Hello world -
The tall-deer is: can a failed-open ECT sensor cause a no-start with liquid fuel in the intake manifold and tailpipe?
Long version: I have a '94 V6 4WD on which I just finished a complete engine rebuild(long-term project, I spent about two years on it).
Last Thursday I started it for the first time: it took probably 30 seconds of cranking before it started; chugging at first but quickly smoothing out and settling at 1500rpm. I worked out all of the air from the coolant, stopping and starting a few more times over the next several minutes(it never started quite right away, cranking and chugging for a few seconds each time before settling into an idle, but seemed to start better when warm), set the timing at 10*BTDC, and messed around checking connectors, clamps etc while it warmed up. It settled around 800rpm, oil pressure and coolant temperature good, and I took my wife and kids out for a celebratory drive around the neighborhood, maybe two miles, before parking it for the night. I noticed a bunch of black specks/spots on the driveway right by the tailpipe, and assumed it was just rusty crap that had formed over two years of sitting and been jarred loose by the heat and vibration of starting after so long. Compression was 100-105psi all round before first startup. It ran for about 90 minutes in total, and aside from difficult starting it ran just fine(anyway, a damn sight better than it did with a burned valve and poor compression in two other cylinders).
The next day, I went to start the truck and it just cranked for several seconds without catching. It started farting and chugging a bit, puffing white smoke(not steam) from the tailpipe and nearly starting, but would not run after I stopped cranking. Thinking it to be a fuel issue, I pulled the cold start injector and set it in a cup, cranked for a moment and found a very small amount(1/2-1tsp) of fuel in the cup, but then I had to stop to take care of the kids and couldn't get back to it that night.
Tonight I went outside, just for fun tried cranking for ~15sec(again lots of farting and almost-starting but no success), and started testing the usual suspects(in order of ease of access :)). Noticed a little stream of liquid in the tailpipe. I tasted it to be sure it wasn't water or coolant, and I suppose it's gasoline mixed with rust... it tasted like shit and I probably now have tongue cancer. I now assume that the black spots I'd seen the day before were liquid gasoline that had run out the tailpipe carrying rust and general filth along with it, fallen to the driveway and soaked into the concrete.
Cold start injector, coil, AFM, TPS all ohm out properly per the FSM, mechanical timing does not appear to have jumped(distributor rotor is where it belongs, anyway). There were no trouble codes.
I ohmed what I thought was the ECT sensor, got 80 ohms(cold engine, ~55* ambient temp) and thought "AHA, bad sensor for sure, problem found"! Loosened the upper intake to get a socket around the sensor, and noted gasoline pooling on the bottom of the upper intake and throat of the throttle body. Anyway, I pulled the sensor, then dangled it in some ~150* water on the stove. It was then that I realized that I had pulled the cold start injector time switch(d'oh). Resistance stayed at 79-80 ohms. I stuck it in the freezer and later checked it, got 40 ohms. Guess that's fine, and I get to put back the expensive sensor and focus on the cheaper one, yay. Too bad that one is even more difficult to reach.
While the CSITS was chilling, I ohmed the actual ECT sensor, which appears to be open. I have yet to pull the thing, because even with the upper intake loose it's still a really cramped spot under all the heater hoses and other crap and I can't get a socket or wrench around it yet, and again I had to come assist with the kids at bedtime. I'm going to head back outside now and see about pulling the ECT so I can verify it's actually bad, but I would appreciate any thoughts you might have as to whether that could be the source of my too-rich almost-but-not-quite-start problem, and why it might've either failed after a first warmup or why the truck started several times with it having already failed but now will not. I wonder whether it would start again if not for the gasoline pooling in the intake.
That's a long read and thanks for getting through it. I didn't want to leave out anything which might have been important.
I've made much use of this forum during the rebuild and appreciate any more help you might have to offer now.
- Ben
Changed the ECT and symptoms are unchanged.
Pulled CSI connector and it seems to have improved; it seems a little closer to catching.
I have an old igniter that I'll try when I get home later.
I forgot to mention earlier that I had the six main injectors bench-tested and rebuilt before putting the engine back together.
Shucks.
You might try posting your question here:
86-95 Trucks & 4Runners - YotaTech Forums
The yotatech forum has more activity and generally more knowledge about these old trucks. This forum seems to specialize in 3rd through 5th gens, not so much in 2nd gens.
It does sound like something is drowning your intake in raw fuel. You might also do the ohm meter checks on the AFM to see if it is possibly providing wrong information.
When you set timing, did you close the T1 and e1 terminals in the diagnostic port? I didn't see that in your first post.
RonJR: thank you for the referral, I will post over there as well. I did ohm out the AFM and everything was within spec.
mholme, I did use a paperclip to jump E1 and TE1, although I didn't think to check whether the MIL was flashing before turning the key to start. Might have been good contact, might not have.
I have replaced the igniter with a spare, with no perceived change.
It seems to be hitting better after I pull the EFI fuse and crank a few seconds to blow out anything already in the intake, then try again.
I have checked compression again out of frustration and found 0 compression at 1 and 6. Doesn't even budge the needle. Others are exactly where they were the first day. I am blown away right now. Don't even know what to think. I am going to take a shower and forget about the truck for the night.
Thanks for your thoughts, guys.
I'm a little suspicious of your compression measurements. Your original numbers were 100-105, which is quite low. It should be upwards of 160 on a rebuilt engine. I'd check for the cams being out of time and/or a slipped timing belt. Compression numbers near 0 generally mean a valve isn't closing on the compression stroke.
The 3vze is a non-interference engine, which means even if the cam timing slipped, you've done no damage.
Thanks RonJR, you were on the right track, though I didn't want to think it could be true :I
I came across many accounts of people with serious overfueling problems having cylinder washout cause zero or near-zero compression, who were able to restore piston oil seal by cranking to blow out the excess fuel, squirting oil into the affected cylinders and retesting. I did all of that and got 150psi on one of the good cylinders but no change on the two bad cylinders. A leakdown test showed air shooting out the throttle body in each case.
I pulled the driver-side cam cover and have found the #6 intake valve stuck open. I don't know any more yet, but I wasn't able to free it by tapping on the bucket. I'm going to open up the passenger side and see what's going on over there.
What puzzles me most about this is the fact that the freshly-built engine ran wonderfully for a test-drive but wouldn't turn on the very next morning. I would imagine that poor work or misassembly would have made itself evident immediately. Really puzzled.
So, I pulled the heads this past Monday(a great deal faster the second time, thank you very much :P). #1 intake was stuck fully open - I couldn't even rotate it, let alone slide it closed. I could overcome the valve spring pressure with my thumbs at each of the "good" valves, but #6 had crept closed at some point and I could not move that one by hand although I did get it down by turning the cam sprocket. It again crept closed over the next few hours.
I brought the heads back to the machine shop and the owner said old gasoline was the cause and that he will clean the heads, but I need to have the tank boiled etc or replace it or the same thing will happen again.
The truck had sat for about two years while I did the work as time and money allowed, but I had run the tank nearly dry and diluted whatever was left with new fuel so thought I would be okay. Anyway, the interwebs are awash with stories of people having similar problems with old gasoline(older than mine, usually, but who knows). Oops. Costly mistake.
I expect to get it back together next weekend, assuming I get the heads back and the new tank shows up in time. I'll let yall know.
Edit: I should mention that when I pulled the cover, timing was spot-on.
- Ben
I feel for you Ben, its obvious from your write up you put a lot of work into the rebuild. Its exciting to crank up a new motor after a timely and expensive rebuild.It seems like you've gone through the electrical system in search of the culprit, what a pain! I didn't know older gas could cause the valve to bind in the guide????
I am doing a similar rebuild on my sons 92 V6. I finished the motor and am prepping the other things like fixing all of the damaged connectors on the engine harness. I'll watch closely as you get the heads installed and go thru start up again. I hope you nailed it and the gas and the stuck valves are behind you and the motor runs fine.
Someone also mentioned the initial compression check appeared low. I don;t know if it makes a difference on a fuel injected motor but I always had the throttle full open during cranking. Good luck!
Please keep you post going.......
Update: '94 V6 CNS issue resolved, bad gasoline
kc15842, thank you for the reply! I apologize for not responding but I hadn't seen it until today.
I had been on the complete wrong track fishing for an electrical problem - I guess I just couldn't make myself believe that I had a compression issue, even though my ears told me that was the case. You're correct about opening the throttle for a compression check, and in my worried haste I forgot to do that this last time. I don't know how much of a difference it makes, but either way it'll be good to remember.
In any case, my wife took the kids yesterday morning for an overnight trip to give me some uninterrupted truck time, and I got it all wrapped up around noon today. It took ten or fifteen seconds of cranking to start, but when it did start it caught right up and ran smoothly. Just like last time, I freaked out when the idle started surging and coolant started steaming/popping out the radiator neck, and just like last time that all stopped as soon as I worked some air pockets out of the system(which did not take as long this time, as I did not drain the block). No hiccups, all gauges reading normal, I got the timing set at 10* and took it out for a quick drive. Everything seems to be good so far. I have not done a compression test yet, mostly because my wrists are scraped up enough already and I can hear as the engine cranks that the cylinders have even compression.
In addition to all of the engine parts I had previously replaced, I had to buy a new head gasket set and bolts(and I regret not going through engnbldr this time, I feel his HGs were of higher quality than the Rock ones I bought locally), and rather than have my fuel tank reconditioned I bought a new aftermarket one for about the same cost. Also replaced the fuel pump and fuel filter, and ran some carb cleaner through each injector using a syringe, rubber hose and 9V battery. Dropping the tank was a major PITA, mostly because of the tight quarters around the filler and vent hoses, and I hope not to ever have to do it again.
I don't expect to have any further problems as I have either cleaned or replaced every part of the fuel system, but I will follow up in a day or two.
Now to get to the "little" stuff... the sometimes-working master window/lock switch, the dead dash clock, install the CB, get an alignment done(I also replaced a really clunky idler arm).
I have taken notes on things I did that others may overlook, as well as things I did "right" the second time or that I was able to work around instead of disassembling, and I will get it written up for another post.
I hope your son's truck went together nicely, and thanks again for the thoughts.
Take care - Ben
Crookedcat
